Old 10-13-2011, 04:23 PM   #1
GMC1965
Need some tranny help and some parts help
Hey everyone, placed an order few days ago for all my panels,lens, mirrors, and all new brakes. Not to bad pricing either. I used classic parts . Com. Anyways, My trannsmittion runs and shifts good but it leaks. The truck is a 65 c10 GMC 283 4 on floor. The tranny has a half inch of oil on it. Any ideas? I also needed help on parts I needed 2 I think. The heater panel (deluxe heater) Inside cab(three levered panel to the right of the radio). It has no levers? How do I remove it to look under there for some broken knobs? I am also having a hard time looking for GMC c10 logos above the L/R rear fender.
Thanks in advance!
Heres some pictures!
GMC1965 is offline   Reply With Quote
Old 10-13-2011, 04:58 PM   #2
padresag
Re: Need some tranny help and some parts help
yours is a model 910. the 9 denotes canadian model gmc
ron
padresag is offline   Reply With Quote
Old 10-13-2011, 05:04 PM   #3
GMC1965
Well that helps alot! Thanks! No wonder I cant find it on american supplier sites....
Old 10-13-2011, 05:10 PM   #4
kieth
kieth's Avatar
I believe I saw a set of the deluxe heater controls at Kenny's Truck Parts in Tulsa, Oklahoma.....Give him a call he might be able to fix you up.....I already got the grille .......Kieth 918-827-2600---these will be used you will not find new parts to my knowledge.
kieth is offline   Reply With Quote
Old 10-13-2011, 05:22 PM   #5
PAPA KENT
PAPA KENT's Avatar
first of all are you sure that the transmission is leaking and not the engine leaking back on the trans? as far as the heater goes you will see two screws on the outside in the upper two corners and if i rember right there is only one support bracket on the back side,there is a light bulb on the top to remove then either remove your cables or lower the assb. down so you can see it then you will see where the (levers) are.they are levers not knobs and by the sounds of it they are broken off which is somewhat common on this design.they are alunimum which explains them breaking.i hope that helps.
PAPA KENT is offline   Reply With Quote
Old 10-13-2011, 05:41 PM   #6
GMC1965
Id would surprise you what they have available. Take a look. The price is way to high and I only need switches.
ANyone know if I only need knobs like the one below?
http://www.classicparts.com/1964-66-...ctinfo/68-466/
http://www.classicparts.com/1964-66-...ctinfo/68-480/
Old 10-13-2011, 05:48 PM   #7
GMC1965
Yeah, prev. owner told me about the tranny and The engine oil never goes down... And thanks for help on removal. I forgot the back one. Do you think I can rig them back to work? The levers?
Old 10-13-2011, 06:00 PM   #8
GMC1965
Also is that red switch next to control's factory? If not hmmmmmm....
Old 10-13-2011, 06:16 PM   #9
PAPA KENT
PAPA KENT's Avatar
no the red switch is'nt factory,as far as the former owner telling you that the oil level has'nt dropped in the engine or trans does'nt mean anything.it takes a pretty good leak to drop your levels and when you see the transmission covered in oil well one of them is leaking.put some on your finger and smell it,80-90 w gearlube has a smell of it's own and of course you can tell the smell of engine oil. as far as your (switches) go the fan control will be a switch and the other two are cabledriven,(take it out and you will see),i assume their the same as chevrolet.if so check with jonzcustomshop here,i gave him good levers and he might be willing to part with a few.
good luck!
Old 10-13-2011, 06:25 PM   #10
GMC1965
good luck!
I meant I looked the engine oil over and its the tranny oil. Very very thick (distinct smelling oil). Do you know were the top up is? Picture maybe? Yeah thanks I will definitely give him a call thanks!
