Old 08-11-2011, 01:18 AM   #1
RossRinSD
RossRinSD's Avatar
Questions about a disc brake conversion on a 69 K10
So, I'm building a 69 K10, and interested in doing a disk brake conversion. I happened to pickup a rebuilt Dana 44 out of a 1981 K20 complete with disc brakes.
Am I on the right track?
I'm assuming I should also pick up a master cylinder for a 81ish K20. And probably the front brake lines and proportioning valve.
Any idea if the current brake booster is good to go?
I noticed that there are sometimes different piston sizes in the master cylinders available. What should I be looking for?
Hey, thanks for the help guys.
RossRinSD is offline   Reply With Quote
Old 08-11-2011, 05:06 PM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Questions about a disc brake conversion on a 69 K10
You can do it just by replacing to prop valve and removing the check valve from your MC, but it may just be easier to pull a booster-MC-prop valve assembly off a donor truck. It all depends on your budget really. I used to go to Ecology down in Vista, or Gallants in Oceanside when I lived in Fallbrook. I was actually there 2 weeks ago and I have to say I MISS IT!!!!!!!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-19-2011, 12:59 AM   #3
RossRinSD
RossRinSD's Avatar
Okay, so I picked up a proportioning valve with the proper residual check valves from CPP. I also purchased the correct rubber lines for the new axle.
Any idea if the flex lines will bolt up to the hard lines in the frame?
I'm putting off cracking open the brake lines to check because I really don't want to have to bleed the brakes again.
1969 Chevy K10
1984 Chevy Monte Carlo SS
1998 Chevy Camaro Z28
2004 Chevy Silverado
2010 Chevy Colorado
Old 10-19-2011, 10:06 PM   #4
kwmech
Good chance that the 1981 axle assy is a 10 bolt and not a 44
kwmech is online now   Reply With Quote
Old 10-20-2011, 05:49 PM   #5
RossRinSD
RossRinSD's Avatar
10 bolt in the front?
1969 Chevy K10
2010 Chevy Colorado
Old 10-20-2011, 09:18 PM   #6
Axle
Axle's Avatar
78-87.
Alex.
Axle is offline   Reply With Quote
Old 10-26-2011, 09:38 PM   #7
msgross
msgross's Avatar
subscribed... i'm doing the same change over....
sounds like you are on the right track...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
