Drop spindles
What drop spindles can I use and still keep my drum brakes up front
Posted via Mobile Device |
![]() Join Date: Sep 2011
Re: Drop spindles
I don't think that's possible.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
60-66 Nut
Re: Drop spindles
All the dropped spindles for these trucks are designed for disc's
Re: Drop spindles
Ok thanks for the info
#5 | |
Re: Drop spindles
Better yet look around for a non running or wrecked burb 89 to 91, I bought one with a fresh engine, transmission, and rebuilt front end for $1,000.00 used it all in my build, tilt wheel, power steering, power brakes, engine tbi 350, transmission, wiring harness, in fuel tank pump (that is a story all to itself) power steering sector, etc......saves a bunch of money............. you still have to buy drop spindles but in the scheme of things it is not much to spend for the looks and performance of your truck. |
#6 | |
Re: Drop spindles
Re: Drop spindles
I got aftermarket 6 lug rotors to stay with the 6 lug pattern. I figured if I had to buy rims I might as well stay all the same around.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
#8 | |
Re: Drop spindles
60-66 Nut
Re: Drop spindles
That is incorrect.
All 3/4 ton trucks thru '87 were 8 lug. Starting in '88 the light duty 3/4 tons (7300 GVW) had 6 lugs. However those rotors will not work on the '71-'87 spindles. They will only work on the '88-'98 1500 and LD 2500 spindles. If you want 6 lug rotors on the '71-'87 spindles, you will have to purchase the aftermarket rotors available from suppliers such as CPP, and ECE.
