Chevy Lover Till The End.
Started on the Tubs
I'm startin the Pro-Street build on my '69 Chevy early, I just can't wait any longer, lol. I'm goin with a wood bed but I wanted to go ahead and do my wheel tubs so I'm using the steel bed as my "mock up" so to speak. Here's what I started with
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
Re: Started on the Tubs
I was runnin a 15X8 Pro-Star look alike made by Pacer with a 285/70/15 which are under one of the new tires I'm goin with, Hoosier Quicktime DOT 31/16.5/15
The Billet R/T wheels, they look alot like the Pro-Star, should be here by Friday along with the tubes. I talked to a feller at WELD and he said they won't stand behing a Pro-Star wheel goin on a truck so that's why I went with the Billet R/T wheel.
Ohh yea, here's the Muscle in Old Blue
Very nice...can't wait to see the finished product!!!
1993 ECSB Drag truck project 2003 CCSB 4X4 Daily driver WWW.MIDWESTSTREETCARS.COM |
Thank you, there are a couple of trucks on here that have this done. That's where I got it from, lol. I went and picked up another set of wheel tubs today and I'm gonna clean em up and see what i've got.
Here's a couple of pics of how I did mine
![]() ![]() ![]() ![]() ![]() Posted via Mobile Device
I'll give you a pointer. When you take out the rest of the bed bolts tighten them with an impact till they snap instead of loosening them. Its much easier.
Lookin good. I love the fat tires.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Hey man, thanks alot for the pictures, very very neat job you did! Also, thanks for the advise on the bed bolts, I'll try that. The tubs I picked up were already widened but two pieced together & also way to wide for what I'm doin but they have very nice sides. The tubs on my parts truck are really beat up so I'm cuttin the spot welds on these tubs I got & goin back with just one seam. I'm gonna Drill the new holes & bolt both pieces back on the bed but over lapped & make one straight cut, throw the overlapped piece in the pile, then I should have a nice close straight fit to tack back together. I love the fat tires too! I'm gonna put a posi unit in instead of a spool. I ran a mini-spool in my chiken truck & when I drove it on the street & turned to sharp it kinda tried to bind up. More pictures to come.
![]() Join Date: Jul 2009
Truck is looking GREAT! I did it the same way and it turned out looking good.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
Thanks feller. You did one heck of a good job on yours, they look Awesome!!!! I noticed you went a little wider than me & also left your bump stop bracket on. I'm gonna cut mine off I think. I would like to find me a pair of narrow 5" drop springs. I'm runnin 4" drops now but would like to go a little more but don't want to notch my frame. I put 3" drop springs in the front & I like them. I'm gettin ready to head out to the garage & mock up one of the tubs so there should be more pictures to come soon.
I cut the stock bump stops off and now in the process of installing a rear c-notch,rear shock mount and anti-roll. Cpp offers a 5" coil spring but the recommended a c-notch to be installed.
Posted via Mobile Device Posted via Mobile Device
~Rest In Peace~
heres mine ,they took two and welded them together ,im running a 31 inch and a 33 will fit with no problems
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Yea, that's where I got my 3" front 4" rear kit. I'm gonna wait til I get the tires mounted & see if the rear still needs to come down for the look I want. If I have to do a notch I will. Man i'll tell ya, I get out there in my garage playin with my truck & it's the closest thing to heaven there is for me, lol. I ain't nowhere near the Man I was before I became disabled but I've got everything pretty much lined out in my garage so I am able to do quite a bit of stuff. Are you gonna post a thread on your project? I sure hope so.
#15 |
I forgot to ask, Do you know if the 5" spring from CPP is narrower?
#16 |
Looks good, how wide of a tire are you runnin? I see you mounted your fuel cell in the same place I'm gonna mount mine. I'm gonna mount my battery in the right front corner. Yep, that's what i'm doin is takin two tubs & makin one but I picked up a set of tubs that had already been widened so I'm takin them apart & just using what I need to do mine with one seam.
#17 |
I took a few pictures of last night's progress. Here is one of the tubs I picked up that had been widened with both sides of a tub overlapped with a piece of metal, tacked together then silicone spread over the two tacked seams
I just marked a semi sraight line usin a piece of thin cardboard & let it overlap then after gettin it where I wanted it I drilled a hole in each end of my bed where the tub is gonna bolt, bolted it down, put 3 bolts back in to the bedside to hold the tub still & made a thru cut with my zizz wheel then used the jig saw to make the cut. I got it tacked together enough to remove it from the truck & plan on finishin the tacks on it tomorrow & hopefully gettin the other tub cut apart & at least cut & tacked if not finished. I had doctors appointments today then my chickens so I decided to just stay in tonight after gettin them done. More pictures to come.
#18 | |
~Rest In Peace~
#19 |
Now thats alot of rubber on the ground!! Looks GREAT!!!! Did you modify your frame? What all did you do to the rear?
#20 |
I got to play with my truck a little last night. I don't have a good Mig welder, just a Flux core wire feed. I'm just gettin em tacked enough for the ride up to my buddy's garage that's gonna do the body work and paint but here is where I'm at now
This is how the wider tubs are gonna look but it's kinda dark
#21 |
~Rest In Peace~
narrow the frame and rear end 12 bolt
#22 |
Thank you for the picture & advise. I may do that in the future but for right now I'm just gettin some meat under him, wood bed, some interior work, upgrades to the motor & color. This is my winter project as I hope to be ready & able to drive Old Blue to the spring Rod Run in PForge.
#23 |
Well, I've decided to go ahead & finish the tubs myself. My buddy said last night it's probably gonna be the 1st week of Jan. before he can start the body work on my truck, he's gotta finish a '71 Olds convertible first. So, I'm gonna make due with the welder I have & try to get em in primer before we leave for vacation in about a week. I'm afraid even though everything is in the garage the bare metal will start rustin with the dampness in the air. More pictures to come...
#24 |
Well I got one tub welded & sanded to bare metal, went to take pictures & the batteries are dead in my camera lol. I'll pick some up tomorrow but I went ahead & pecked what few dings there were out as best I could & spread a very light skim coat of short strand filler on it. I'll get some pictures tomorrow if at all possible. One good note, a buddy came by to see if I had any good double humps, told him I had a pair of 461, a pair of 462's & a pair of 186's but I was keepin the 186's for a 406 build one day but would part with either of the other two sets. Long story short, I now have a very good Mig welder!!!! No more flux wire for me. I traded the 461's for it, I just have to get my own tank. He's suppose to bring it over Sat. along with the cart, extra tips etc.... He said it started with an S he thought but it came off the MAC truck. I have saw it & used it before but it's been a few years. He got a new 220 Miller Mig.
#25 |
We are back from Vacation as of Thursday night & I hope to get back to playin with the wheel tubs & my "New to Me" welder. It's a Solar brand, made by Century but Lincoln bought Century so I'm callin it a Lincoln welder, lol. My neighbor signed for my wheels that came while we were gone & I had the tubes & tires mounted yesterday. I'll post some pics soon as I get the vacation pictures uploaded so I can use the camera.
