Old 11-03-2011, 04:45 PM   #1
Heavy1/2
Heavy1/2's Avatar
74 2WD C20 Body swap onto 87 K20 4x4 frame and running gear?
To make a long story short I've found a 1987 GMC 2500 4x4 for a very decent price... The truck is complete 350/400 NP208. I want to swap the cab and core support from of my 74 C20 (2WD) onto the 87 frame and running gear.
I know I'll have to modify the front portion of the 87 frame to fit the 74 core support, and remove the 2WD tranny hump... I was just wondering if there would be any other foreseeable porblems?
I read somewhere that I might run into clearance problems trying to fit the NP208 under the 74 cab... Can anyone confirm this? I'm sure a small body lift would help?
Cheers!
YOUR MONEY'S WORTH. MILE AFTER MILE AFTER MILE.
Heavy1/2 is offline   Reply With Quote
Old 11-03-2011, 04:59 PM   #2
J Knight
J Knight's Avatar
Re: 74 2WD C20 Body swap onto 87 K20 4x4 frame and running gear?
I dont know about the 4wd stuff but the cab will bolt to frame mounts you just have to use 81-87 cab bushings. The frame brackets for the core support only need to be moved about 3/4in.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-03-2011, 05:16 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I have never moved the core support mounts on the ones I have swapped.
If you don't use a body lift, you will need the trans tunnel from the original as the 2WD hump won't work. Is the 87 cab that bad?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-03-2011, 05:28 PM   #4
Heavy1/2
Heavy1/2's Avatar
Thanks for the info! Every bit of advice helps. I'm sure it's going to be fairly straightforward. I was basically curious whether someone has done a similar swap . Good to know I can get away with just moving the factory rad support brackets a touch.
Old 11-03-2011, 05:43 PM   #5
Heavy1/2
Heavy1/2's Avatar
I knew I'd have to modify the trans tunnel. The cab from the 87 is in much worse shape than the Cab on my 74... The cab on the 87 will need new rockers and cab corners at the very least, I haven't had a chance to inspect the floor yet.
Thought it would be neat to swap the 74 body onto a platform with slightly more modern components. I thought about modifying the frame on my C20 and putting in longer/larger springs front and rear, shackle reversal etc. etc.
I paid very little for the 87. I would have spent much more time and money trying to modify the frame on my C20.
