Old 11-01-2011, 10:23 PM   #1
BustedTruck
BustedTruck's Avatar
Any one upgraded to 3/4 ton calipers?
I am looking to upgrade to the JD7/JB7 brake calipers. They have the larger piston and brake pads. The calipers bolt up fine, but the hoses will not. I am redoing my 40 year old brake system and this seems to be a budget upgrade. Has anyone done this before? Could you tell a difference? Am I going to run into any other problems?
BustedTruck is offline   Reply With Quote
Old 11-02-2011, 12:13 AM   #2
c1069
c1069's Avatar
Re: Any one upgraded to 3/4 ton calipers?
subscribed
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 11-02-2011, 10:17 AM   #3
BustedTruck
Anyone done this?
Old 11-02-2011, 10:26 AM   #4
longbed67
longbed67's Avatar
I am very curious about this as well!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 11-02-2011, 09:19 PM   #5
BustedTruck
Well I went ahead & ordered the brake hose. I should know something in a few days. I am considering purchasing the 3/4 ton booster also.
Old 11-02-2011, 09:28 PM   #6
Willys47
Willys47's Avatar
I am curious about this to!
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 11-02-2011, 09:50 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I was under the impression the calipers and pads were the exact same between the 10 and the 20 series trucks.
Old 11-03-2011, 11:18 AM   #8
BustedTruck
The larger calipers I want to use are from something like an 1980 k20 suburban. They have a the larger 3 5/8 piston diameter & use a slightly larger brake pad.
Old 11-03-2011, 09:40 PM   #9
BustedTruck
Here is a photo of the pads. Top ones are for the larger caliper, & the lower is the original pads. I got the brake hose today for the suburban, it will thread into the line and with a new bolt, the line will bolt to the caliper. The suburban brake hose is like 4" too long. It would be good if anyone out there has a pic of how a similar line is mounted?
Old 11-03-2011, 10:17 PM   #10
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Good idea, I'll be watching to see how it turns out for you.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-03-2011, 11:20 PM   #11
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Im in
John
1999 Toyota Tacoma 4x4
Old 11-04-2011, 12:43 PM   #12
jaros44sr
jaros44sr's Avatar
What size wheels are going to be on your truck....nice upgrade. Thanks for posting up
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-04-2011, 01:40 PM   #13
BurnoutNova
BurnoutNova's Avatar
I did a 3/4 ton swap on my 86 K10, the calipers bolted up fine, pads were fine. I used AN braided line for my hoses though, so I never had an issue with them being to short. I haven't actually driven it more than around the block yet, but everything seems fine now.
The larger piston will give you a little more stopping power, but I think it's minimal. I didn't think the booster or master cylinder were different?
BurnoutNova is offline   Reply With Quote
Old 11-08-2011, 10:11 AM   #14
BustedTruck
The calipers clear with 15" wheels. I ordered some Stainless Braided lines to fit & they leak at the sealing washers. I have reinstalled the lines 3 times with new washers every time. I am so frustrated right now every thing is going to go back to stock parts. Oh well it was a nice thought.
