Old 11-10-2011, 08:19 PM   #1
darush01
Help!!!!!
My clutch went out in me 72 c20 350 4 spd i replaced the clutch pressure plate and throwout bearin but i still have no pedal, upon further investigating i found the pivot rod from th frame to the block is cracked can this be welded back even if its only temporary?
darush01 is offline   Reply With Quote
Old 11-11-2011, 12:09 AM   #2
tasian
tasian's Avatar
Re: Help!!!!!
i would say so as long as you can get a good weld on it where it cracked it should be good as new cant end up worse then mine that the PO notched out to clear the headers
oh and just a heads watch for the grease inside to catch fire when your welding on it
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
