Broken shock tower
Hey everyone,
I have a broken top shock tower on the rear passenger side of my 82 K30 and have called local junkyards but no one has a 1 ton, only 1/2 or 3/4 ton trucks. I've looked around on the Internet but can't find anyone that sells them, my guess since the thing is riveted on the frame. My question is: will the 1/2 or 3/4 ton trucks shock towers fit the 1 ton or is it strickly 1 ton only? I haven't had the time to go to a junkyard to compare the shock towers so I'm hoping someone here can help. Any and all advice will be greatly appreciated. Thanks in advance. Eric
"Fork: an instrument used chiefly for putting dead animals into the mouth." - Ambrose Bierce 1982 Chevy K30 |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Broken shock tower
AFAIK the one ton is an animal unto itself.. id check the parts board sometimes people part one tons try member teeitup hes a vendor
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
There are no shock towers on the 1/2 ton. The upper shock mount just bolts to the frame with a shock bolt.
Just throwing this out for something to think about, see other attachment, which shows the upper mount for a 1999+ ck. Look similar? If you goto Monroe, you can see if the upper shock eye is the same between the 1 ton and the 99, if it is, graft on an upper mount from a later truck. Alex. |
As 'old rusty c10' stated, the C/K30 utilizes an upper bracket specific to the C30 chassis. They mount inboard of the frame-rail vs. the upper stud that attaches to the outside of the frame on the smaller trucks.
You could look for someone parting a C30 out or build a new mount from steel.
when i bought monroe shocks they came with the shocks
(sensatrack)
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Thanks for all the responses.
Upon closer inspection of the shock tower today, I found that the shock bolt that is welded to the tower was broken off and not the shock tower itself. I felt relieved to see that, so I think I will fabricate and install a shock bolt for the thing and call it a day. Thanks for all your advice. Eric
Glad you can work this out man.
FYI, GM is also a decent source. My Dad's 94 K1500 rear shock mounts rotted out, but he was able to buy new pieces from GM. That may also be possible for the C/K30 squares |
