67cheby
![]() Join Date: Sep 2008
any preference on aftermarket doorhandles for a 67
thinking about buying aftermarket (original style) chrome outside door handles for my 67, is there one brand that is nice than another ? or are they all made in the same place ? also what has to be done to make these work on the 67's i know something is different about the mounting points just not sure what it is ?
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 11-14-2011 at 05:12 PM. |
1969 Custom 30 wrecker
Re: any preference on aftermarket doorhandles for a 67
I can say one thing, they all start pitting in about 3 months if your truck is outside. By 6 months, you'll wonder why you even bothered.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
VA72C10
![]() Join Date: Mar 2008
I'll add that they're all made with plastic at the mounting points which can and likely will fail in short order. Might be worth looking into finding a decent used set of 67's and having them re-chromed....NOS 67's are worth 300 on the low end for a pair....
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
67cheby
do you have any....i have a pretty decent set off of my truck but the potmetal is cracked around the spring deals and when they go to take them apart it is going to just break off
![]() Join Date: Dec 1999
NOS 67's are impossible to fine I have been looking for years. I might have a extra set of used I would have to do some digging
67cheby
that would be great , thanks !!
![]() Join Date: Sep 2007
The 67 outside handles have mounting points that are angled vs. all the other years which are straight
1967custom |
VA72C10
I will check in my box as well to see if there are any 67's in there....
Junior Member
You can learn something new all the time around here.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
67cheby
thanks for everyones help
![]() Join Date: Jan 2002
Yes 67 is by itself. Inside door handles, outside handles, vent windows and also upper door hidge id different. Im not saying a complete hidge want work, but you cant use the door catch off newer years on a 67.
The door has extra bracket welded in the inside that makes the door Handle different. Just in case anybody didnt know.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
#13 | |
VA72C10
67cheby
they are pretty cool...hmmm ...no, no more changes just the factory style door handles !!
#15 |
Project '67 454
Here's the thread on what i did to mine
http://67-72chevytrucks.com/vboard/s...d.php?t=371898 I'm not doing a restoration so I didn't mind cutting the inner bracket.
67 C-10 SWB Fleetside 454 (current project) ![]() 99 Crewcab SWB Dually 454 ![]() 75 Datsun 280ZZ430 ![]() 94 Formula 232LS 454 ![]() |
#16 |
67cheby
just checked out that thread....thank you very imformative showing what the actual differnce is !!
