Old 04-22-2003, 07:50 AM   #1
Ed ke6bnl
exchaning 12 bolt carrier.
I need to know if I can and how to exchange carriers from one 12 bolt 3.73 for another 12 3.73. The present one is noisy. The replacement has a worn posi (want to rebuild but another question) Am I correct that I need to pull the axle then ?? remove pinion nut and flange and then carrier bearing caps and pull out carrier assembly. Will I need to be concerned about crush sleeve and or gear meshing. Any help the book has completely confused me. Ed ke6bnl So.Calif.
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
