Old 12-21-2011, 05:50 AM   #1
wwj75c30
wwj75c30's Avatar
straight axle swap??
so im about to straight axle my 75 c30 i hava a dana 44 and getting 6" lift springs
whats the best way to make spring mounts and shackle mounts?
wwj75c30 is offline   Reply With Quote
Old 12-21-2011, 06:33 AM   #2
wwj75c30
wwj75c30's Avatar
Re: straight axle swap??
actaully more like would it be hard to do the swap?
Old 12-21-2011, 10:55 AM   #3
ghettoluxury
ghettoluxury's Avatar
The easiest way is to order new ones. The next and cheapest way would be to get them from a junk yard. They are rivited in and are a pain to remove. The swap has been done many times look in the build threads.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-21-2011, 01:59 PM   #4
bikes&bowties
bikes&bowties's Avatar
I built my front ones out of box which I cut in half to make channel and then built the mounts for it to go on the frame with angle. I really wish I had pics but I don't. I then used plate and round tube to make the rear hangers. Mine were done fast and are pretty crude. It would be easy to finish them and make em pretty. On a scale of 1(first time touching a car) to 10 (work in a professional shop) I would say this project is about a 6-7. You will need a different crossmember also.... You will need power tools, torch, welder/fab skills (not very good skills needed)
bikes&bowties is offline   Reply With Quote
Old 12-21-2011, 05:13 PM   #5
wwj75c30
wwj75c30's Avatar
so if i get the mounts and a new cross member it shouldnt be very hard?
Old 12-21-2011, 05:43 PM   #6
wwj75c30
wwj75c30's Avatar
i think i saw your build thread? for a 79? you made your ownd cross member?
Old 12-21-2011, 09:28 PM   #7
ghettoluxury
You will also need a 4x4 steering box unless you are going with crossover steering.
Old 12-21-2011, 10:49 PM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
check out this thread, this guy is do'n one right now. it's not as hard as it sounds if you have a donor truck.
http://67-72chevytrucks.com/vboard/s...74#post5077174
I think you can mod you exsist'n cross member and not change it if you want'd to also.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-22-2011, 12:54 AM   #9
wwj75c30
wwj75c30's Avatar
do you know how you can mod the cross member? i was kinda just thinkin about that
Old 12-22-2011, 01:06 AM   #10
nekkidhillbilly
idk enough about the differences but im sure you could build one out of tubing pretty easy
nekkidhillbilly is offline   Reply With Quote
Old 12-24-2011, 07:08 AM   #11
wwj75c30
wwj75c30's Avatar
doesnt the stock 2wd one just hang down to low?
Old 12-24-2011, 08:23 AM   #12
BigBlocksRule
Find a 4WD K-5!
There are a lot more folks looking to go the other way, seems to be a huge following for 2WD K-5's. You'd probably be money ahead, plus a lot of time!
BigBlocksRule is offline   Reply With Quote
Old 12-25-2011, 11:31 PM   #13
wwj75c30
wwj75c30's Avatar
arent k-5s blazers?
