Old 02-23-2012, 11:40 PM   #1
4xshort
4xshort's Avatar
Frame crossmembers
I was hoping someone can "Straighten" me out, I have a 1971 shortbox 4x4
the very front and very rear crossmembers look like they have had a chain
hooked up to them and got bent out of shape. Can I use a crossmember from
a 2wd or does it need to be 4wd, will a blazer match up? Is it possible to put
in rivets like the factory or would proper bolts be fine?
Thanks in advance Josh
4xshort is offline   Reply With Quote
Old 02-24-2012, 12:52 AM   #2
oldschool18
oldschool18's Avatar
Re: Frame crossmembers
2wd and 4wd are differant but 4wd truck and blazer are the same you might have a hard time finding someone to rivit them
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 02-24-2012, 11:31 AM   #3
JimKshortstep4x4
I believe rivets are available but I have not used them. Some guys use 7/16" bolts and drill the holes for a tight fit. I used some metric button head bolts on the last cross member as they fit tightly in the existing holes. After painting they look like rivets from the button head side.
3/8 bolts will work but they are a little loose in the holes.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-25-2012, 12:24 PM   #4
med.bronze
med.bronze's Avatar
I had the same issue on the rear crossmember on my "72. I wanted to keep the original look so I searched for rivets and found them at www.bigflatsrivet.com. I was also able to buy a rivet head forming tool for an air hammer from this guy.
med.bronze is offline   Reply With Quote
