Old 12-30-2011, 02:53 PM   #1
RastaRobb
RastaRobb's Avatar
Pilot Bearing removal
What ticks do you have for removing a stubborn pilot bearing?
RastaRobb is offline   Reply With Quote
Old 12-30-2011, 03:21 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Pilot Bearing removal
Fill the cavity with grease. Slide a dowel in that fits the ID and whack it with a hammer.
Old 12-30-2011, 03:24 PM   #3
RastaRobb
RastaRobb's Avatar
Ahhh, I'm pick it up what your putting down. Any need to heat it first?
Old 12-30-2011, 04:13 PM   #4
travis401
is it an actual bearing, or just a bushing? parts stores rent slide hammers with a busing removal attachment. you slide the arms in the bushing, tighten the nut to expand them, then slide hammer it right out. the grease method works too, but its more messy and takes longer.
travis401 is offline   Reply With Quote
Old 12-30-2011, 04:49 PM   #5
RastaRobb
RastaRobb's Avatar
Your right, it is a bushing. Not sure why it is listed as a "bearing".
Old 12-30-2011, 10:48 PM   #6
KrazyRay
KrazyRay's Avatar
The grease trick works great.
KrazyRay is offline   Reply With Quote
Old 12-30-2011, 11:19 PM   #7
rayfinseats
Yes the grease thing works great.
rayfinseats is offline   Reply With Quote
Old 12-31-2011, 12:33 AM   #8
bowtiemanchevyman
bowtiemanchevyman's Avatar
i use a tap thats the same size as the hole and comes out really easy and fast. and its a lot cleaner then Grease and easier. ive been useing it for about 10yrs and never had a problem with it.
bowtiemanchevyman is offline   Reply With Quote
