Old 12-29-2011, 12:37 AM   #1
scotts72heavyhalf
scotts72heavyhalf's Avatar
Thumbs down A-arm bushing question
I am rebuilding the entire front end of our 69C10, I had the a-arms blasted and powder coated and replaced the control arms and bushings, it looks like the book calls for a torque of 270 ft. pounds ont he lowers and 170 on the upper bushings. My question is: Are the bushings supposed to seat completly into the a-arms? Mine are about 1/4 to 1/2 inch away from being fully touching the a-arm, I dont want to over tighten them but it seemds they were completly seated against the a-arm when I removed the ols ones?
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 12-29-2011, 08:04 AM   #2
rob32472
Re: A-arm bushing question
Everyone I have ever done or seen have been fully seated.....
rob32472 is offline   Reply With Quote
Old 12-29-2011, 09:57 AM   #3
hairlesshobo
hairlesshobo's Avatar
I don't know if this helps your or not but check out post 49 of "make it handle." Rob mentioned something similar to this so it might help ya.
http://67-72chevytrucks.com/vboard/s...4&postcount=49
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread
The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears
hairlesshobo is offline   Reply With Quote
Old 12-29-2011, 12:14 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
Not 100% sure on your '69, but on the 73-87 versions, the upper control arm bushings have a gap between the control arm and the flange of the bushing. The outer shell of the bushing has a step that will bottom out when the bushing is pressed in place, leaving approximately a 1/4" gap. The lower control arm bushings press in flush, no gap.
I just did this job 2 days ago using all Energy Suspension parts.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-29-2011, 03:00 PM   #5
scotts72heavyhalf
Thanks guys, I am going to try a cheater bar to see if I can get a bit more of a seat, I just dont want to bend the a-arms but 250lbs of torque is a bunch.
Scotts72C10
Old 12-29-2011, 05:31 PM   #6
stomper
Junior Member
stomper's Avatar
Did you powder coat the threads on the a-arms? Maybe you have a situation similar to mine?
I also had my arms powder coated and had a helluva time screwing in the bushings. (Bent my cheater bar) I believe it was a mistake for me leave the powder coat on the threads of the a-arms. Doh! Mine were not that snug when I took them out so I figured it a good thing to leave the powder coating on for a tighter fit. I'll probably take it all apart and clean that up.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
