Old 10-22-2011, 09:39 AM   #1
glljr
Rear
Does anyone know if a 67 rear will fit in my 71. I just checked and I have 308 gears outback and found a rear at my buddies junkyard that is in a 67 6cyl 3 speed manual I am assuming it has a 373 or 411 gear.
glljr is offline   Reply With Quote
Old 10-22-2011, 09:57 AM   #2
cdowns
cdowns's Avatar
Re: Rear
a 67 rear is 6 lug pattern so you'd need new wheels for the back
Old 10-22-2011, 10:39 AM   #3
glljr
Re: Rear
would the axles be the same I can just swap them out right
Old 10-22-2011, 12:14 PM   #4
67cheby
67cheby
67cheby's Avatar
Re: Rear
the 67 rearend will be narrower than your rearend
67cheby is offline   Reply With Quote
Old 10-22-2011, 12:15 PM   #5
67cheby
67cheby
67cheby's Avatar
Re: Rear
it will fit and then you could run wider wheels, and no you wont be able to swap the axles because of the width
Old 01-07-2012, 05:56 PM   #6
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Rear
When I pulled a rearend out of a 71 6cyl that had 3:73 gears to install in my 69 I just took the pumpkin and pinion. Once installed I notice my drum was at least a 1/4 inch past the backing plate. I found out that after 69, the rearend is different. One of my axles went into the rearend deeper than it should have. I dont know if it was the housing or the rearend pumpkin thats different but if I have to do it again, I will take everything.
VDOG is offline   Reply With Quote
