Frame off resto help needed!
I have never torn a vehicle down to the frame and built it back up with new components........What sort or order or plan should I follow? I want to do it right but have no idea how to do it to keep me on track. Currently it has no interior. I will be adding a McGaughey's 4.5 / 6 static drop with either 18s or 20s. I want to do it right and keep myself moving forward and avoid as many pitfalls as I can along the way. Any help will be greatly appreciated.
RIZ ![]() |
Re: Frame off resto help needed!
Step one: establish a budget.
Step two: double your budget. |
Plastic bins and organization. Take out stock in sharpies. I have disassembled my Chevelle and all of the components are in boxes and totes with toe tags on them to keep track of all of the parts. As I restore a part I put the tag back on it. Also figure out the direction you want to go so you do not waste money on parts you do not need.
1 disassemble the entire truck and keep track of all of the parts. 2. Survey the parts and the vehicle as to what you are going to need to get the job done. 3. Make a parts list of have to have and nice to have. Nice to have can wait until the truck is running and back on the road. For me and the Chevelle is air conditioning. 4 Start re-assembly from the ground up. |
Robert Olson Transport
![]() Join Date: Oct 2002
what I would do is to do each item section by section.. Id get all the parts for the drop and put that toegether... While youve got the suspension off id clean the frame and put on your frame paint and assemble it... I personally found if i did things in some kind of order and was able to keep the truck running and usable while i was doing it i still had a truck to use and i was able to keep myself interested. the truck i tore to shreds and started building up all in one shot became too overwhelming for me
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Take lots of pictures so you can reference them if you need too.
i agree with stew-magoo......there will be obvious things you will need to replace and the ten other parts conected to that part may need replaced while apart so you dont have to go back in later
put all your screws and fasteners in zip locks and mark with sharpie
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
Originally Posted by Stew_Magoo Step one: establish a budget. Step two: double your budget. I agree with everything. I also have a Chassis/service manual for my year. It's helpful on some stuff. This forum is another great resource |
78K & 79C Jimmys
i found a small sand blaster great for cleaning things up
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
What always helped me from loosing bolts washers and screws is once you take the part off, put the fastener right back in the hole. Obviously take it out if you need to sand or paint that area, but where it came from is the best spot to keep it. Like it has been said before, do a section at a time. Itll look like a big mess at times but dont let it get you down. The hardest part about doing most things is getting the guts to try it the first time! Dig in! lol
X2! after restoring mine I wish I knew then what I know now about these squares lol. I'm helping a buddy do his and its way easier the second time around.
I can testify to this.....especially if any NOS parts are involved
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
