Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Old 01-21-2012, 08:10 PM   #1
notyo_cheez
Cool 1993 seat in a 84 cab - how I did it
To read the original thread and discussion on this topic go here- LINK
Removed base from 93 seat. Cut one piece of 18 ga unistrut to fit width of seat. (Unistrut can be found at Home Depot, about $20 for a 10' piece. In the electrical department. It is typically used with threaded rods and other hardware to suspend overhead conduit, pipes, etc. in commercial/industrial installations although it's a multipurpose product.)
Mounted screws in holes, applied a dab of red paint on the screw heads so I'd know where to drill.
This is a lousy pic, shows the seat brackets from the 81 mounted on the unistrut after I had them on the floor of the cab to mark their position. Used 1" 5/16 grade 8 hex bolts and nuts, flat and lock washers. Marked for the holes in the unistrut with a Sharpie, worked out pretty well.
Mocked up in the donor cab, another lousy pic. Took a little persuasion but the bracket holes lined up in the nuts in the floor. Got started a little late today so this was all I managed to get done.
Don't have 220 or a MIG for the garage (yet?) so this was my best effort. Will have to take it all apart again and send the bottom seat upholstery to a shop to get the tear fixed, or I might just get it all redone. Thinking about a custom hot rod job using Mexican saddle blankets, haven't decided yet...
notyo_cheez is offline
