Old 03-18-2012, 09:23 AM   #1
3QTRTONS
3QTRTONS's Avatar
'84 6.2 Burb + 91 6.2 motor = water pump issue! Help!?!
Bought an '84 Burb that the PO had replaced the original 6.2 Diesel with one out of a '91 (or '92). The '91s serpentine system was gone so he set up a V-belt system on it. Ran it up and down the road; went fine. Long idle; fine.
Sold it to me. Driving it home, (12 miles) the temp pegs!
Am I right in figuring that the water pump is flowing in the wrong direction? I've googled this and it seems to show there may be a problem replacing the '91 water pump with an '84 because of the backing plate and/or timing cover may not be compatible between the two engines? If this is the case, is there such a thing as a reverse flow water pump for these?
OR,,,,,,, am I looking at this all wrong!?!?!?
1969 ES5500 B E A S T 1976 K20 Suburban
1983 C10 'farm truck' 1984 K10 Suburban
1988 V30 Fire Truck
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
