'63 Third Brake Light on Cab?
I'm finishing up the cab sheetmetal, and wondering if I want to add a third brake light there, and open to ideas. First I was thinking of an LED strip in the tailgate, but how would it look on the back of the cab? Anybody done this?
292 + TKO500 |
Re: '63 Third Brake Light on Cab?
i had been thinking about this on my 65 DD. i saw someone using a tahoe third light somewhere. i wondered if there was a clean inside the glass unit myself.
Senior Enthusiast
For a 3rd (& 4th) brake light, I installed a set of Ron Francis red Brite Lites on the back of my cab:
http://www.ronfrancis.com/prodinfo.asp?number=BL%2D69R They are rather discrete, and are connected to the brake light circuit so they come on as blinkers, stop lights or when the 4 way flasher is switched on. They do not light up when the tail lights are on. Along with the four Cadillac tail lights, there’s a lot of stop light power at night. For emergency situations I also have a pair of amber bullet style Brite Lites at the top of the rear stake pockets. On my truck these are operated independently by a police car headlight wig-wag flasher. Red lights mounted in this location could serve as high mounted brake lights instead on the cab: http://www.ronfrancis.com/prodinfo.asp?number=MC%2D61 Here’s how they all look on the truck: ![]() ![]() |
![]() Join Date: Aug 2004
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Resistance is Futile
I was just staring at the 60-66 wiring diagrams; where do you tie into the brake light circuit so as to avoid the turn signals?
I'm stealing my 3rd brake light from a billet license plate frame that is now illegal in AZ 'cuz it covers the state name....wasn't using it anyway! ![]()
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Here's what I used from a 1999 Chevy Suburban
I wired directly from the brake light switch. Bob |
You mean the switch on the column mount, correct? This is where it seemed to be the most simple to me.
hey clyde65 do you have a pic installed?
yes, I will post in the morning.
There is a build thread somewhere on here where a guy shaved his drip rail and installed one. Looked super clean.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
Hardly noticeable at all except when brakes are used. The assembly didn't quite fit the contour [radius] so I used a little black silicone sealant to fill in the ends.
Bob |
#15 |
Big Fenders,
Would have any additional pictures of your third brake light? Maybe from the rear or close up? Thanks, Blue666 |
#16 |
Here is what mine looks like
#17 |
"Where were you in '62?"
![]() Join Date: Jul 2004
I will be using the Third Brake/Cargo Light from a 2003 Ford F150.
It is contoured to fit perfectly in the lip and will be perfect addition with cargo lights. And it's bad......... ![]() ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 12-27-2010 at 02:34 PM. |
#18 |
Keep us updated. What's the easiest way of adding 3rd light.
#19 |
#20 | |
Bob |
#21 |
#22 |
Bob,
Thanks a bunch. Really shows that the light fits up tight & close, no gap. Looks like a must do, easy cheap project. Thanks, Blue666 |
#23 |
Bob,
When you fished the wire inside the cab did you take the dome light out for better access or was that not necessary? |
#24 |
I have the light from the '68 style on mine works and looks great
The next step for me in an LED Bulb for less heat on the very close plastic lens |
#25 |
Wow, this is great info guys. What a great board we have here. Thanks for the leads. Clyde, that one from Julianos sounded too thick (deep) in the description, but looks pretty thin on your truck. I'm thinking it would look good above the rear glass too. Are you pleased with it?
Big Fenders may have the bomb tho, I like that look. Bob, how does that 'burb unit fit/look/and work in that location ( It's mounted upside down, and not parallel to the line of sight from the rear ) Did you have to add any drain holes or anthing? Bad62, have you done one of the F*rd units yet or seen one on our trucks? -Tad
292 + TKO500 |
