Old 03-09-2012, 11:51 AM   #1
Jake65
65 Chevy c10 questions
Im 16 and have some questions and could use some assistance. In the 4 speed top loader on the back of a 292, how do you remove the shifter from the tranny? Me and dad think that we have an idea how but we'd like to hear it from someone who can verify our thought. My other question is, can you use the stock intake for a 292 and still run headers? Anything will be helpful. May post pics of both soon for a visual reference.
Jake65 is offline   Reply With Quote
Old 03-09-2012, 12:06 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 65 Chevy c10 questions
push down on the cap and turn. I think counter-clockwise.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-09-2012, 02:11 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
That sounds familiar.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-09-2012, 03:20 PM   #4
1963c-10
1963c-10's Avatar
You can use the stock intake, but you have to put a delete plate on the bottom & run either water or exhaust bypass in to heat the intake. The original intake is an integral unit with the exhaust/intake bolted together by three bolts. The exhaust has a spring that opens an internal heat riser that normally heats the intake. Id check with Tom Langdon, he has a web site for inline parts. Check with the inliners forum also.
1964 Short bed trailer
Old 03-09-2012, 05:27 PM   #5
Jake65
Thanks for the help i will definitely try that the next time im out there, i will also check about the intake because moneys a little tight and i was dreading having to buy another intake
Old 03-09-2012, 05:49 PM   #6
1963c-10
1963c-10's Avatar
Tom Langdon's has the delete plate for the factory intakes. He acan tell you how to plumb the intake to heat it also. He is a wealth of info on chevy inline 6 engines.
