![]() Join Date: Sep 2007
tilt column rebuild Qs
I am wanting to rebuild a tilt column i picked up. its from a 70 4WD but i have no idea where to start. do any of you know of a thread to help me tear it apart and rebuild it
1967custom |
![]() Join Date: Oct 2009
Re: tilt column rebuild Qs
not all-inclusive, but might give you some idear -
http://67-72chevytrucks.com/vboard/s...highlight=tilt http://67-72chevytrucks.com/vboard/s...d.php?t=329008 http://67-72chevytrucks.com/vboard/s...d.php?t=386933 http://67-72chevytrucks.com/vboard/s...d.php?t=313820 http://67-72chevytrucks.com/vboard/s...d.php?t=194740 |
![]() Join Date: May 2006
Upper upper, and lower upper bearings are getting hard to find....check with Wes at classic heartbeats, he may have been able to find another set by now.
I will also say when i did mine the bearings were not to be found. Take care with the tear down. Gary
Service manual is a great source of info., exploded view for reassembly and special tools required, pullers, slide hammer. The two pivot pins can be pulled with a bolt, nut, washer, and a socket of the correct size...
you know thats a good idea. I didnt even think of my 70 chevy service manual.
ill check out those websites now. the bearings still feel good so hopefully I wont have to replace them. I mainly have to tear apart the upper portion where the tilt is to run the turn signal switch wiring. but Im check those bearings for sure now classic heartbeats.....ill drop wes an e mail
1967custom |
#7 | |
