Old 03-15-2012, 10:04 PM   #1
rustic
Question 61 torsion bar truck, can the little block under the bolt serve a purpose?
Does the little block that is located between the head of the bolt and the cast torsion arm have a purpose? I am considering removing it and replacing it with a heavy washer this will gain about a half inch of ground clearance and add more thread to the top threaded blocks. What are the pros and cons?
rustic is offline   Reply With Quote
Old 03-15-2012, 10:54 PM   #2
dthela
dthela's Avatar
Re: 61 torsion bar truck, can the little block under the bolt serve a purpose?
why would you need more thread? I don't think you would ever need more adjustment up or down on the torsion bars than there is now. Unless you want no suspension or solid suspension
dthela is offline   Reply With Quote
Old 03-15-2012, 10:56 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Looking at photos 17 & 18 in the 1960 Chevy Truck Shop Manual, it appears the square block(s) you are talking about both on the bottom by the head of the bolt, and the square nut/plate on top, have anti-rotation properties designed into them, keyed by the half round block to the adjuster arm itself.
Replacing the lower plate with a flat washer may cause the bolt to unscrew over time. This could risk losing adjustment, or the bolt itself if it unscrews far enough. This might be prevented if the bolt is long enough with the lower plate removed to double nut the top of the bolt which would in effect lock the bolt in place. This is assuming you can even find an extra nut the correct size.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-15-2012, 11:08 PM   #4
rustic
thanks for the info markebo1 i thought that might be some sort of locking set up for the bolt, but was not sure. you have been a help to me and from what i see everyone on this site. you should be proud of your wealth of knowlege about these trucks.
Old 03-16-2012, 02:32 PM   #5
doobiebro
doobiebro's Avatar
I second that...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
