Rivits!!!!
I guess you can tell by my heading that I'm having some trouble with the rivits on my '63. Some of them have come out with grinding the head off then using a BFH on them. Others, not so much.
I just wanted to see if anyone had a real solution to getting these things out. I'm wanting to install a sway bar and need to get the rivits out to do so. Thanks for your help Cody |
![]() Join Date: Nov 2003
Re: Rivits!!!!
Here are some good ideas: http://67-72chevytrucks.com/vboard/s...d.php?t=291939
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: Rivits!!!!
Thanks for the reply.
I've tried the grinding and punch method but, some of these things are really stuck in there. Is that just what to expect? |
#4 | |
Re: Rivits!!!!
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
Re: Rivits!!!!
some times you nhave to say some bad words,sometimes not
![]() Join Date: May 2012
Re: Rivits!!!!
Easy way I did it. Step drill, take the head of with a flat chisel and then punch them out.
Re: Rivits!!!!
Have also found that sometimes, the parts are in a bit of a bind, so clamp the parts tight, then drill /grind, or chisel the head off, and punch out. Just a little bit of twist and cause the rivets to bind up.
Never Ending Projects
Re: Rivits!!!!
I found once I bought a high quality air chisel/hammer (mine is a Snap-On) the rivets come out much easier.
I used to X pattern cut the head and the air chisel them off but I ran into areas where I couldn't cut a X pattern, hence buying the new Snap-On one. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: Rivits!!!!
I have to agree with mike making a x with a angle grinder knocking the head pieces off a quarter or half at a time with a flat chisel then knocking them out with a punch. A small sledge helps and so does some huevos haha good luck.
Posted via Mobile Device |
Re: Rivits!!!!
I had to use the drill and chisel method on bumper carriage bolts also. I have seen a few 1st gen c-10's that had castle nut style nuts on the bumper bolts which fill w/dirt and have destroyed the nuts over the years.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Hollister, CA.
![]() Join Date: Sep 2006
Re: Rivits!!!!
The EASIEST way I've found is to use a cut off wheel .... cut a slot down the middle ....
Then, all it take is a slight taop with an air chisel to slice them out.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
![]() Join Date: Aug 2011
Re: Rivits!!!!
I drill them out and then use the BFH and a punch to push them out.
Use 3 sizes of bit, small pilot hole, one about 1/2 the size of the rivet and the last one the same size as the rivet. Not the head of the rivet but the actual rivet diameter.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
meowMEOWmeowMEOW
Re: Rivits!!!!
If you have a spot weld drill it will do a rivet head, but I also like using the punch on an air hammer if its a thick enough piece.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: Rivits!!!!
Grind off the head and the "BFH" technique to get them out. On some of the more stubborn ones I had to drill and then punch. Just keep at it and don't give up! Some times you need to walk away for thirty minutes and then come back to it.
#15 |
Re: Rivits!!!!
I had good results with an air chisel/hammer. Used a chisel bit to pop the heads off and a punch bit to push them through.
#16 | |
Stirrer of the Pot
Re: Rivits!!!!
haha that applies to everything on a truck with 52 years of rust on it! ![]() |
#17 |
Re: Rivits!!!!
#18 |
Re: Rivits!!!!
i like to use the plasma cutter i cut the head off then blow a hole though the rivet u could probably do the same with the torch and more finess. using heat to blow a hole throught the center shrinks the rivet and lossens all the rust.
Projects: 66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350. |
#19 |
Re: Rivits!!!!
Remove the head of the rivet as suggested, then heat the area around the rivet with a torch to expand the metal. With a hammer and punch it should pop right out.
#20 |
Re: Rivits!!!!
I guess the rivets I'm having the most trouble with is the ones that have 2 pieces of metal around them. The areas with single metal have been ok.
#21 | |
Re: Rivits!!!!
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
#22 |
Re: Rivits!!!!
Scarf the head off with a scarfing torch tip then use a air chisel. In most cases 2-4 min ordeal per rivet.
#23 |
Re: Rivits!!!!
Grind the head off and drill the rivet to nearly the same diameter as the rivet body. But DON'T go quite all the way through! Then put use a punch and hammer to knock it out. This stretches the rivet, which shrinks the diameter of the rivet body and makes it pop out easier. Just trying to knock it out with a punch will actually "peen" the rivet material outward, causing it to swell and make it tighter in the frame.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#24 |
Re: Rivits!!!!
Smoke wrench is the best thing to use.
#25 |
meowMEOWmeowMEOW
Re: Rivits!!!!
how do you smoke a wrench?
which end are you supposed to light ![]()
