Old 04-06-2012, 04:19 PM   #1
ctandc
'83 front suspension onto '65 frame - different bolts?
I'm using the upper and lower control arms, spindles, rotors, calipers and complete steering linkage from a ’83 C10 to swap onto my ’65 C10.
Mine were already removed from the donor truck.
Will I be able to use the bolts that hold the ’65 control arms to the front crossmember / frame to bolt on the ’83 control arms?
Anyone know if they are different?
____________________________
ctandc is offline   Reply With Quote
Old 04-06-2012, 07:47 PM   #2
SCOTI
SCOTI's Avatar
Re: '83 front suspension onto '65 frame - different bolts?
The 'u-bolts' that clamp the lower a-arms to the x-member are a different size on drum brake vs disc brake trucks. You can drill out the x-member for the larger diameter u-bolts or re-use the originals @ some risk since they're smaller/less strength.
Everything else is the same from what I remember....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-07-2012, 01:14 AM   #3
ctandc
Thanks.
I'm close to having the drivetrain out.
