Old 04-03-2012, 06:36 PM   #1
warbucket
warbucket's Avatar
8 lug 16.5 wheel ?
I have a dana 60 and 14 bolt axles for my 72 blazer and have a chance to pickup a set of 78 ford f250 stock steel wheels, I heard they will fit but can I get the small chevy hub caps to fit them? I'm going for the factory look.
warbucket is offline   Reply With Quote
Old 04-03-2012, 08:54 PM   #2
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: 8 lug 16.5 wheel ?
I have F**d rims on mine also and the hubcaps fit just fine.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 04-04-2012, 06:09 AM   #3
I believe Joe has the later 7 x 16 Ford wheels that have out nubs for hub caps like any normal wheels should. But,Ford's not normal and back when the 16.5s were used it's possible they are the inner nub type that only accept Ford hub caps. Look for the outer nubs. If it has those they are fine. If they are the 9.75 wide wheels chances are they may have gotten the outer nub type. Just check to be sure. Here's what you want shown on stock GM 16s and wide 9.75 x 16.5s:
Old 04-04-2012, 11:58 PM   #4
warbucket
warbucket's Avatar
Thanks guys for all the info. Here's a pic of two. The silver one looks like the nubs come out, I can't see the white one that well but I see small holes between the stud holes and the valve stem location .
Old 04-05-2012, 05:13 AM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
Looks like the nubs are out on the white one too - right by the valve stem.
Old 04-05-2012, 06:15 AM   #6
Now that I think about it,I'm sure in '78 the Ford hubcaps were outer nub type and those sure look right. I thought I'd let you know. I just sold those wide steel wheels to a guy in PA last weekend and it turns out he can't use them because he has Wilwood discs. The brackets are welded and his axle is already powder coated. If you might want to go wide steelie let me know and I'll get you in touch with him. I see you're in PA and these things are heavy to ship. Just thought I'd give you the option to help my fiend Bill out.
Old 04-05-2012, 09:59 AM   #7
warbucket
warbucket's Avatar
That would be great, I'm definitely interested in the 9.75" wide rims. My plans are to run 33-12.50 tires.
Old 04-05-2012, 06:29 PM   #8
That would be cool if this works out. I'd buy them back from him,but I only sold them because I needed the money pretty bad. I just saw where he posted them for sale . Here's the link...good luck:
http://67-72chevytrucks.com/vboard/s...d.php?t=517963
Old 04-06-2012, 10:51 PM   #9
warbucket
warbucket's Avatar
I called him and I was about an hour too late, they were sold.
Old 04-07-2012, 08:40 AM   #10
duallyjams
duallyjams's Avatar
I have 4 stock rims that came on a 79 3/4 4x4 and 2 nos with light surface rust in the box 9.75. I"ll try to get a pic later today.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-07-2012, 09:31 AM   #11
warbucket
warbucket's Avatar
Thanks James that would be great, I was just down your way on Wed to pickup a frame at Richard2717 house.
Old 04-07-2012, 05:00 PM   #12
duallyjams
duallyjams's Avatar
stock 79 16.5 / not sure what the width is
9.75 / 16.5
James
IG duallyjams
Old 04-07-2012, 09:09 PM   #13
warbucket
warbucket's Avatar
Thanks James I'll sent ya a PM about the rims.
