71 c10 static drop
i got rear 5 inch springs on way ,,front 2 inch are here ,new upper lower ball joints , cpp , now i need front 3 inch drop spindles what will work with stock steering? and 15 inch wheels ..later i will get some 18 front 20 rears ,i seen the belltech ones they have two styles ductile iron and then some other ones ? or is there a diffrent brand thats better ? stock disc brakes
#2 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 71 c10 static drop
The only issue you will have is when your 15" wheels have more than a 3.5" backspacing. Even then,... all you have to do it take a grinder to the leading edge of the lower control arm. (in the ball joint area)
yeah i did the drop over this weekend and it dropped it alot and i see where the rim hits i need to do a little more grinding
Looks good!
thats 5 inch rear springs , 3nch belltech drop spindles and 2inch springs , i need to do the drivers side front tomorow i tore a upper ball joint boot so i need to find another one or buy another balljoint , dont ask ...but i now know how they go back together ,hhaa when its all done i will get it on solid ground and see if i need lower the rear anymore,im just worried its gonna rub on fender with those rims and tires someday i will buy new ones but net is body and apaint for next few months goin with original medium blue , other wise my dad wont paint it for me ,, i wanted cream orange with vanila top
well i grinded all i can grind on the lower a arms and it wont seem to work with those rims , im gonna have to find some 16inch or bigger wheels , there close but bolted down they rub enough to not turn by hand , unless i can shave the inside the rim and get balanced probly price new rims,
