Old 04-08-2012, 05:36 PM   #1
biohazardbill
Air Ride Install.. Questions about location of components
This is going into 65 Burban. I know I will be mounting the tanks between the rear quarter and the frame however wondering where alot of you mount the rest of the gear. I would like to be able to access it for troubleshooting etc so I was thinking about putting everything inside however wouldnt that also put the pressure relief inside the cab as well making it noisy when lowering? With it laying frame if something went wrong, near impossible to get to.
Looking for ideas, suggestions.
biohazardbill is offline   Reply With Quote
Old 04-09-2012, 11:03 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Air Ride Install.. Questions about location of components
Any Burb owners with pics?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-10-2012, 08:47 PM   #3
biohazardbill
Bueller.......
Old 04-10-2012, 09:30 PM   #4
broey
Square
broey's Avatar
the closer you run the valves to the bags the less air it will take to fill them. thats about as helpful as I can be on a burb.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-11-2012, 04:06 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
Have you already purchased your valves? The only reason I ask is because if you haven't, I would recommend you getting some type of manifold set up like accuair's for sheer simplicity of installation and room it takes up. I think it's well worth the additional $ when comparing it to 8 separate valves.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 04-11-2012, 04:39 PM   #6
**grumpy**
**grumpy**'s Avatar
Heres how my buddy did his 63 burb.
2 compressors mounted on a swing down bracket at rear pass side.
tank in center
valves etc for rear in homemade vented box(which will be painted black) on drivrs side rear.
Road Hounds
**grumpy** is offline   Reply With Quote
Old 04-11-2012, 05:57 PM   #7
Pro Performance
Pro Performance's Avatar
If you had to run the valves inside, you could laways route the dump outside in order to keep the noise down. As for compressors, I mounted mine on the back part of the frame right behind the rear bumper. I am not sure if there is room for this on a 65 burb, but might be worth checking out.
Pro Performance is offline   Reply With Quote
