Old 04-12-2012, 12:21 PM   #1
mdstitt
4L80E In TF Truck
I am wondering if a 4L80E behind a LS engine will fit under the floor or if a tunnel needs to be fabricated. I have a Direct Sheetmetal set-back firewall installed and the front suspension is No-Limit Wide Ride, so I have a little more room but I'm still not sure if it will fit.
Pictures would be great! Thanks.
mdstitt is offline   Reply With Quote
Old 04-15-2012, 02:21 PM   #2
hotrod1
56 - autocross
hotrod1's Avatar
Re: 4L80E In TF Truck
Go take a look at my build 56 pro touring (I think). We are putting a 4l80e behind a ls. Fits ok. We are going to set the engine back 3 inches and will need to drop the engine 3/4 inches (for handling purposes). Does not look like we will have to refab the tunnel.
What are you doing for engine mounts? Do you have a build on this site?
hotrod1 is offline   Reply With Quote
Old 04-15-2012, 03:00 PM   #3
mr48chev
mr48chev's Avatar
I think it's like running a Turbo 400 in that it depends on exactly how high and where you set the engine in.
Old 04-15-2012, 09:14 PM   #4
solidaxel
solidaxel's Avatar
Are you running that much H.P. that you need a 4L80E?
Those 80's and a bunch larger than the 60's.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-16-2012, 12:45 PM   #5
mdstitt
My thought was that a 4L80 would work pretty much in it's stock form with maybe just a shift kit for the fun factor. I am figuring on roughly 450 hp to start and possibly adding a turbo later or a stroked LS3. Once more power is added, i will have to build the trans a little more.
A 60E would probably need to be built right from the get-go.
Old 04-16-2012, 12:48 PM   #6
mdstitt
[/QUOTE]What are you doing for engine mounts? Do you have a build on this site?[/QUOTE]
I will be using custom engine mounts that I may fabricate myself or the tubular ones from progressive automotive.
I do not have a build on this site.
Old 04-16-2012, 12:49 PM   #7
hotrod1
56 - autocross
hotrod1's Avatar
You are right. The 60 needs to be built and you always are a little sketchy about it lasting. It weighs about 60-80 lbs less but I heard that they are OK up to 450.
The 80 is bullet proof as it is. Build it a little bit and it will handle what ever you throw at it, with in reason. I dont ever want to worry about it again. That is why I went with a 80 and a for 9 from curry. Drop the hammer.....every time.
Old 04-16-2012, 12:59 PM   #8
mdstitt
Also, I checked out your build. Awesome.
I am also using the No-Limit Wide Ride on mine. I have a Direct Sheetmetal set-back firewall/floor, so I have a little more room than the stock firewall/floor allows.
I like your engine mounts too. Thanks for the replies.
Old 04-16-2012, 01:00 PM   #9
wyomech
wyomech's Avatar
I am running a 4l80e with a 6.0 ,but I have a chevelle front IFS so I think that it moves the engine lower than the stock location
wyomech is offline   Reply With Quote
Old 04-16-2012, 01:45 PM   #10
hotrod1
56 - autocross
hotrod1's Avatar
The engine mounts that I am using wont work anymore. When you move the engine back that far you dont have that cross member to go down to. I was thinking about attaching to the tube that comes from the cross member for the bottom a arm bolt and then supporting that to the frame. Just a thought.
