Old 05-24-2010, 10:33 PM   #1
blazed870
LS swap quick questions on motor mounts
I have a 70 C10 that I am going to be putting a Gen III 4.8 with the 4l60 out of a 2000 GMC truck. I want to use the stock manifolds as well. I have been looking at the Trans Adapt 4572 and the 4575 motor mount adapters.
1. Should I get the motor mount adapters for stock location or the ones that push the engine back 1"?
2. If I decide to use a F-body oil pan for more ground clearance, which motor mounts should I use?
3. Are these plates big enough that if I need to move the engine forward or back a little, I will be able to drill out new holes?
Mickey
blazed870 is offline   Reply With Quote
Old 05-26-2010, 10:16 PM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: LS swap quick questions on motor mounts
Hey there Mickey: Welcome aboard!
You might get some answers from this extensive FAQ on LS swaps.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 05-28-2010, 10:43 AM   #3
Clyde65
Clyde65's Avatar
I really dont think you will be able to run stock manifolds unless the ECE motor perches/mounts will allow it. I have used the CPP tubular and the POL tubular mounts, the CPP's wouldn't work for me ( put the motor forward), I used the POL, it puts the motor up and to the rear, allowing for dual fan placement.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-26-2012, 04:55 PM   #4
Ford Assassin
Ford Assassin's Avatar
Digging up an old thread....
I noticed your from Bako, ever get your swap done?
Take care!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 04-27-2012, 09:44 AM   #5
Daaaanz67
Truck pan will not work with ece
Daaaanz67 is offline   Reply With Quote
Old 04-28-2012, 12:25 AM   #6
Daaaanz67
Ece and Ctsv pan fits great this is what I'm using almost a half inch above crossmember got this idea from another member.
