Old 04-18-2012, 01:52 PM   #1
Lockedup
Lockedup's Avatar
Clutch Choice
Hey guys, I have decided to swap out the TH-350 that is in my truck with a T-5 that i have in my shop. My motor is a built 1970-80 400 SBC, I have an aluminum bellhousing to go with the transmission but that is it. What flywheel,clutch/pressure plate assembly would you guys suggest? Also where is the best place to source these parts from and i also need a slave cylinder and pedal assembly. Is there anything else i will need? Here is what i am planning on needing,
Transmission
Bellhousing
Clutch/Pressure plate
Flywheel
Pedal assembly
Slave cylinder
Lockedup is offline   Reply With Quote
