Vent window glass
What is the best way to remove the glass out of the vent window frame, and the lock handle.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
Re: Vent window glass
I use a small drift to punch out the roll pin that is holding the handle onto the shaft.
To remove the glass from the frame I use a flat blade screwdriver that has the sharp edges removed. If you start at the top, the window can be gently pried out without breaking it. It is just a matter of working with it. A little window cleaner sprayed on the seal will help. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
what JimKshortstep4x4 said ^^
I use a punch and hammer to take the roll pin out. and a plastic block or wood block is what I use to tap off the metal off the glass, by placing it on a flat surface and spraying it with window cleaner then laying the block of wood on the glass and tapping with a hammer..
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
Thanks,, gonna give it a shot this evening.
