Old 05-02-2012, 08:51 AM   #1
john@thepier
john@thepier's Avatar
What type of lube 4x4 closed knuckle?
What type of lube goes in the knuckle of the closed front axle?
john@thepier is offline   Reply With Quote
Old 05-02-2012, 10:46 AM   #2
mknittle
mknittle's Avatar
Re: What type of lube 4x4 closed knuckle?
I used 140wt gear oil in my 68 anything thinner would leak worse. some jeep guys use grease. I hated that axle! water in, oil out No mater what I did it leaked. I sure miss that truck though
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-02-2012, 01:08 PM   #3
maxwoof
The manual for my 62 calls for gear oil. Recently, someone posted the Dana factory manual, which you may find helpful. You need to search for it.
When I rebuilt my closed knuckles, I packed all the bearings with wheel bearing grease, like conventional wheel bearings. Now, I do not run oil in the knuckles, except for occasionally brushing some on the felt seals.
maxwoof is offline   Reply With Quote
