Old 05-07-2012, 11:11 PM   #1
RdoubleU
RdoubleU's Avatar
Trac-Bar / Panhard bar Torque Specs
I'm torquing my rear suspension to spec and I have an adjustable rear trac-bar like seen from Porterbuilt or No Limit
Does anyone know the correct torque specs for the bolts/studs that go thru the trac bar ends (heim joints) ??
I'm a notorious over tightener and the assembly manual seems high at 135 ft/lbs if I am reading it right.
Don't want to bind anything or limit travel
RdoubleU is offline   Reply With Quote
Old 05-08-2012, 11:12 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Trac-Bar / Panhard bar Torque Specs
Typically the torque spec will be directly related to the bolt size and grade. Do you know what size the bolt is, and what grade it is?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-08-2012, 11:42 AM   #3
RdoubleU
RdoubleU's Avatar
Nate - I'm going off memory from last night but I believe this is correct
Upper Bolt: Grade 5 - 1 1/8"
Lower Bolt: Grade 8 - 15/16"
Old 05-08-2012, 11:46 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
You will go off the actual diameter of the bolt... not the size of the wrench you use on the head. Google torque specs on the size and grade bolt you have (after confirming when you get home). There may be a slight variance in the spec sheets you find, but you will notice that they will typically all be within 5 lbs or so from eachother.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-08-2012, 12:20 PM   #5
RdoubleU
RdoubleU's Avatar
Something like this?
http://www.cncexpo.com/InchBoltTorque.aspx
Thanks Nate - Always learning
Looks like 100+ft/lbs might not be that far out of line
Old 05-08-2012, 12:49 PM   #6
RdoubleU
RdoubleU's Avatar
Nate - just out of curiosity and completely understanding your information will not apply to my specific application
What would you recommend to someone torquing the bolts holding the trac-bar in your kit to?
Just want to see if I am in the ball-park and not way out of line when i cross-reference my diameter later
