Old 05-02-2012, 09:31 AM   #1
72tutone
ECE Spindle Guys
Do any of you have any clearance issues? I have 15x6.5 rally's on mine and I have heard the offset my be of an issue.
I'm looking at their 2.5" drop spindles with a regular stock replacement coil and 4" drop springs for the rear, and I want to make sure before I pull the trigger that there wont be any issues.
Thanks!
72tutone is offline   Reply With Quote
Old 05-02-2012, 10:07 AM   #2
Normru45
Re: ECE Spindle Guys
i also have this same question.
Normru45 is offline   Reply With Quote
Old 05-02-2012, 10:15 AM   #3
Scottshotrods
Here is one more option for you we do carry Cpp spindals and Cpp dropped & stock springs that will work for your application no problem at all.If you are interested you can p/m me or e-mail me at justin@scottshotrods.com or call me at (805)485-0382
Justin
Scottshotrods is offline   Reply With Quote
Old 05-02-2012, 10:16 AM   #4
72tutone
Why was this post moved?
Just a question, nothing more too it.
Old 05-02-2012, 11:19 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I did not move it, but my guess is so it would get more attention. Now that its in the Suspension Forum our resident experts will see it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-02-2012, 03:20 PM   #6
jackyl9999
jackyl9999's Avatar
I have a set of ECE spindles, and did not have any issues with clearance on my rallys.
Steve
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 05-02-2012, 03:26 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
The 15x6.5" and 15x8" truck ralley wheels have a 4" BS.
The 15x7" truck ralley wheels have a 3-5/8" BS.
15" wheels with a 4" BS wll require trimming of the lower a-arm in the lower ball joint area,... for trucks running the standard design 2.5" and 3" drop spindles.
(removing a little of the "gutter" on each side of the balljoint)
This takes about 5 minutes per side with a electric grinder equipped with a cut off wheel.
Keith
Convert to disc brakes.
Old 05-02-2012, 03:40 PM   #8
72tutone
That sux. I am running 15x6.5 rallys on 235/75/15 all the way around. I'm looking at the 2.5" spindle.
I dont want to have to shave anything off if I buy the spindles. Can you explain where and what would have to be cut off? I guess the alternative is to get the drop spring and the shock relocators?
jackyl9999 what size are you running with no issues?
Old 05-02-2012, 09:33 PM   #9
jackyl9999
jackyl9999's Avatar
15x7
1990 K1500 Daily
Old 05-02-2012, 09:48 PM   #10
lolife99
lolife99's Avatar
This arm has already been trimmed.
The blue tape marks the areas that were previouly trimmed.
I've been doing this mod for over 25 years.
I do it on all trucks I lower with drop spindles.
(you never know when you might have to bolt on a different set of wheels)
Keith
Old 05-03-2012, 08:17 AM   #11
72tutone
Ok, so I should just concentrate on the blue tape then?
Is it the entire length of the tape? How much approx do I need to shave off? Or is it more trial and error?
Any other areas to be trimmed?
Old 05-04-2012, 10:35 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Just bolt the wheel on to the truck and swing the steering side to side. You'll see where the wheel lip hits the control arm. It's completely self explanatory when you see it in person. Like Keith said, 5 minutes and you're done. Like him, I've been doing it since the early 90s on many trucks. Heck, I just did my own truck last week. Don't sweat it. It's a non issue.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-05-2012, 12:37 AM   #13
thelonerife
thelonerife's Avatar
X2. On my truck that I had with 6.5s it would hit the wheel weights. This reminds me I have to do it on my project truck. Or at least check it. Its not a big deal.
thelonerife is offline   Reply With Quote
Old 05-15-2012, 12:59 PM   #14
Gus350
68 C 10
Gus350's Avatar
My truck has a 84 model crossmember put in by the PO will this trimming still be the same on the newer style lower arms?
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 05-15-2012, 02:24 PM   #15
lolife99
lolife99's Avatar
Yes.
Keith
Old 05-15-2012, 03:03 PM   #16
Gus350
68 C 10
Gus350's Avatar
Thanks Keith
Kevin
John Wayne
68 C10
70 C20
Old 05-15-2012, 03:28 PM   #17
Southcity
Southcity's Avatar
TX Firefighter is right - I too am running the stock 15x6.5 steelies up front, one thing I did was to have my tire guy run the sticky weights on the inside of the rim rather than on the lip of the rim and I did not have to trim a thing BUT every application/truck is a little different and trimming the gutter on the A-arm is no biggie.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
