Old 05-27-2012, 10:04 PM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Need quick response, grease in rear wheel bearings?
Is it necessary to put wheel bearing grease on my new rear axle bearings? Aren't they lubricated by the 90wt gear oil?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-27-2012, 10:30 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Need quick response, grease in rear wheel bearings?
If you have the proper fluid level it should lubricate the wheel bearing, but to be on the safe side, I would lubricate them before taking it out for a drive. Can't hurt.
68gmsee is offline   Reply With Quote
Old 05-27-2012, 10:39 PM   #3
airdale94
airdale94's Avatar
No it is not necessary. Yes they are lubricated by the gear oil. I have read recently Dana/Spicer says to. I wouldn't worry about it. I never have. I think it's mainly to aid in break in. If your building a new rear end with a thousand or thousands invested I probably would. But I probably would change the gear oil out after about 500 miles anyway. I think the manual calls for white lithium grease so it will melt (disolve) into the gear oil. That's why you're suppose to use assembly lube instead of grease when assembling a manual transmission.
airdale94 is offline   Reply With Quote
Old 05-27-2012, 10:57 PM   #4
C10_ustacould
Axles and Axle bearings are new, the rest is original.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-27-2012, 11:00 PM   #5
shawno72
C/10 junkie
shawno72's Avatar
I have always greased the rear wheel bearings and have always had good luck and long life out of them. Works for me and I'll keep doing it. My .02
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 05-27-2012, 11:03 PM   #6
canuk99
What I do is, refill your diff then jack one side up 4 or 5" for 5 minutes then lower it and jack the other side for the same time. This ensures you have some oil to the bearings. Cheers!
canuk99 is offline   Reply With Quote
Old 05-28-2012, 12:06 AM   #7
yuccales
yuccales's Avatar
Sounds like a good idea.
yuccales is offline   Reply With Quote
Old 05-28-2012, 12:19 AM   #8
C10_ustacould
Thanks for the responses, I think I am going to throw some grease in there. I sounds like it may hepl prevent premature bearing failure, cheap insurance.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-28-2012, 12:40 AM   #9
shawno72
C/10 junkie
shawno72's Avatar
Good idea.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
