LED Tail light blinker not working
Both brake lights work fine. Driver side blinker works fine. Passenger side blinker doesnt work. Installed heavy duty flahser relay. Wiring is stock. Any ideas?
Re: LED Tail light blinker not working
Have you checked the bulb in the front? If that is not working the rear will not work.
Don't have front blinkers at the moment. The wires for them were cut a while back.
Posted via Mobile Device |
Hollister, CA.
![]() Join Date: Sep 2006
When I had the rock-a-billy (my black truck), I used to roll without the hood.
I ran resisters with my LEDs to get them to flash. However, you mentioned you have NO front indicators as well, but one does work ? Sounds like you might have a turn signal switch issue. What happens with brake applied, and left turn engaged ? Posted via Mobile Device
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
I've had intermittant turn signal issues with both my current 65 and my old 63, and both were fixed by just sanding down the light sockets and screw connections to get the ground good and solid. On both trucks the brake lights "seemed" to work fine, but the turn signals were flaky.
Come to think of it though, I eventually replaced the turn signal switch in both trucks as well... but I would still try fixing the connections first, it's much cheaper. ![]()
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck |
@Cheif; the front signals are not connected at the moment. The driver rear turn signal works perfectly, the passenger rear does not. On the dash, the passenger signal will turn a dim green when the switch is activated, but will never fully turn green.
@billd; these buckets are brand new as well. I'll give the sanding a shot though. Posted via Mobile Device |
Hollister, CA.
Pull the wheel check/clean contacts....
Harness to back ok ? Posted via Mobile Device
![]() Join Date: Sep 2009
you need a special flasher for led lights
That is a ground issue, most of us have run a ground wire from both rear tail light buckets to the cab, problem fixed.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Hollister, CA.
Could very well be .... Just assumed that was checked.
