Old 12-21-2011, 10:14 PM   #1
bark
factory tach???
factory tach??? well almost, started out doing the camaro tach fuel gauge thing to my electronic speedo, didn't like the look of it, so bought a little tach from princess auto, with a shift light, took it all apart, made it fit behind the original gas gauge, installed the smaller maro fuel gauge, got a local decal place to make me a new front for it, and then installed factory needles to finish it off, also installed a factory clock. Not as easy as it sounds, had to remake the hole original housing, and printed board, but it turned out pretty good, and now I can use the 4cyl mode
bark is offline   Reply With Quote
Old 12-22-2011, 01:34 PM   #2
conman585
conman585's Avatar
Re: factory tach???
This looks incredible. Take any more pics during the assembly?
conman585 is offline   Reply With Quote
Old 12-22-2011, 05:05 PM   #3
feller
feller's Avatar
Re: factory tach???
so it is possible to make the 4 cylinder mode work?
feller is offline   Reply With Quote
Old 12-23-2011, 11:45 AM   #4
ls1nova71
ls1nova71's Avatar
Re: factory tach???
Ls engines use 4 cylinder tach out put, so by using an aftermarket tach its possible to use 4,6,or 8 cylinder mode.
Tach looks great! How did you re do the printed circuit? Any pics of the back?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-23-2011, 02:44 PM   #5
feller
feller's Avatar
Re: factory tach???
oh i see
Old 12-25-2011, 11:22 PM   #6
bark
Re: factory tach???
sorry no pics, it was a real b!tch, had to cut apart another housing to make it deeper under the tach for clearance, could have just cut a hole in it, but had more time then that so... lol... then had to cut the printed circuit, moved a bunch of wires around, by re soldering, and extending them because of clearance issues, the gauge was from an electronic speedo truck, and getting put into a 76, so the plug in wires had to be moved around on the truck side to match up with the newer style gauge, also had to run a wire for the oil pressure gauge
Old 12-30-2011, 12:48 AM   #7
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Re: factory tach???
DUDE!!! This is freaking sick!!! SKILLS!!!!!!!!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 05-29-2012, 12:19 PM   #8
bark
Re: factory tach???
uugghhh! all that work, and I can't get it to work???? it worked in the truck I pulled it from, and now there is nothing?
so I went and did some research and I might need to wire in a resistor. Will let you know what happens...
Old 05-29-2012, 01:44 PM   #9
ls1nova71
ls1nova71's Avatar
Re: factory tach???
Most '03 and newer PCMs will need a pull up resistor, a 680 ohm 1/4 watt resistor placed between the power and signal wires on the tach.
