Old 06-17-2012, 07:46 PM   #1
manimal
manimal's Avatar
Help me lower a ....Longhorn
Ok, today I scored a set of BellTech drop spindles from an '84 1ton dually. I know the spindles are the same for dually and non dually. I also looked up the ball joints for a '71 and an '84 and they are the same for a 1ton and 3/4ton. BUT my truck is a '70!
I plan on the non-dually disc brakes(of course),but these spindles have slide on calipers (had hydroboost) that use a wedge to secure the caliper to the spindle. So I plan on getting the calipers for the spindles and a master cylinder to match. My question is can I use that master cylinder with my stock vacuum booster? Or do I have to go hydroboost?
I hope this all makes sense.
OH..also can I use my stock upper and lower A-arms and just change out the ball joints to the newer ones?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 06-17-2012, 08:58 PM   #2
SS Tim
SS Tim's Avatar
Re: Help me lower a ....Longhorn
As I sit here wondering what banging my head on the keyboard would do, I decided to look up some of the front end parts..... Bottom line is I can't help. The GM service arms include the ball joints which are a '70 down application. Try a Hollander manual.
SS Tim is offline   Reply With Quote
Old 06-17-2012, 09:38 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
You will need to change your upper and lower balljoints to 73-87 3/4-ton versions.
Also the outer tie rod will need to be changed to the 73-87 version.
The 70 inner tie rods will have to be swapped to '70 OUTER tie rods,... installed in the inner location.
(to get the correct thread pitch)
You will need a conversion tie rod sleeve to connect the smaller 63-70 tie rod to the larger 73-87 tie rod.
Performance Online or Edelbrock sells them.
Keith
Convert to disc brakes.
Old 06-17-2012, 10:02 PM   #4
manimal
manimal's Avatar
Perfect! Thanks guys!
-Lance
