Old 06-07-2014, 11:37 AM   #1
In The Ten Ring
Fuel line grommet questions......
This is probably a silly question but I thought I might go on and ask. What is the best way to remove the OEM floor grommets (fuel line passes through cab floor) and replace with new ones?
I bought a set of new grommets from Wes at Classic Heartbeat last December.
In The Ten Ring is offline   Reply With Quote
Old 06-07-2014, 11:56 AM   #2
geezer#99
geezer#99's Avatar
Re: Fuel line grommet questions......
Use a big torch!!
Burn em out!!
NO!! NO!! Just kidding!!
Pry em out with a screwdriver, lube the new ones with a little wd-40 and pop em in.
geezer#99 is online now   Reply With Quote
Old 06-07-2014, 12:18 PM   #3
In The Ten Ring
Originally Posted by geezer#99 View Post
Use a big torch!!
Burn em out!!
This is what happened the last time I used a torch on my truck. LOL
http://patperry.net/uploads/blog/200...-fire-blog.jpg
Thanks for the advice man. I'll put it to use today.
Old 06-07-2014, 02:30 PM   #4
airdale94
airdale94's Avatar
Oh man that sucks! Made a neat picture though. What were you torching?
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 06-07-2014, 03:15 PM   #5
leftybass209
leftybass209's Avatar
I just used a chisel and hammer. 1 good swing cut the top off, then poked the rest down the hole with my finger.
leftybass209 is offline   Reply With Quote
Old 06-07-2014, 05:03 PM   #6
In The Ten Ring
I was driving along and BOOM I saw a spider! No action is too extreme where those things are concerned!
