Old 07-16-2012, 09:09 AM   #1
focusedontheprize
focusedontheprize's Avatar
Critique my brake flares
Posted this over in the '47-'59 forum also...
This weekend I tried my hand in flaring brake lines. I have never done this before so I did quite a bit of reading and making sure I followed everything properly. I have a good set of flaring tools (MAC Tools) so quality of tools wasn't a worry.
I started with cutting my lines and trying to keep them square a possible. I used a file to clean up the edges and the outside of the tube just a bit. I then deberred in the inside of the line with a drill bit.
After that I measured the appropriate amount of tube length to leave exposed (measured with the adapter), I then dabbed a little brake fluid on the end (recommended by someone) and then squared up the adapter with the tube. I started my first bubble, took off the adapter, and then flared the end of it. Here is a couple of the flares.
I am looking for feedback. I don't think they look that great and would like any recommendations on my technique. I look at my picture and then look at "great flares" and I am doing something wrong haha.
Thanks.
focusedontheprize is offline   Reply With Quote
Old 07-16-2012, 10:31 AM   #2
RexDodge
Re: Critique my brake flares
If it doesn't leak then it's a good flare, lol. Looks good. Be sure to blow the lines out with air before you install to get the bits of grit out. Good job.
RexDodge is offline   Reply With Quote
Old 07-16-2012, 12:25 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Don't forget to put the nut on.
I've ruined perfectly bent brake lines, by not adding the nut before that last flare.
Keith
Convert to disc brakes.
Old 07-16-2012, 01:19 PM   #4
focusedontheprize
Ha I just want to make sure they are the best I can get before putting them in. Hate to have to remove them because of leaks. I will blow them out, I am actually going to actually re-flare them.
Ha I could imagine. Easy to forget them.
