Radiator overflow
Hey guys,
I'm plumbing my coolant setup on my ls1 swap, and was wondering what everybody is doing for a overflow setup? I'm using my stock radiator, can I just run the overflow hose to a overflow tank? thanks Posted via Mobile Device |
Re: Radiator overflow
Yep, you can put anything in there you wish.
I just left my overflow hose open on my LS swap as that's how GM built the truck anyway. |
okay. that sounds great. thanks
i may just leave mine open also, any issues at all with this setup? Posted via Mobile Device |
No issues for the overflow, millions of cars made that way.
Environmentalists may not like though ![]() An overflow however isn't a bad idea and having a closed cooling system can have some advantages. There are many aftermarket and factory style tanks that should fit your taste. A neat way to do the 67-72 trucks (and I've been thinking about doing it myself) is to take another washer bottle and bracket that is used for the washer/wiper system and mount one on the other fender (passenger side) for an overflow. You just have to change the cap to a dual nipple design. One for the radiator hose and the other is your drain or vent. Doing it this way on a 67-72 truck makes it appear like it's a factory setup... |
awesome.
thanks so much for the help Posted via Mobile Device |
If you run an open system, whatever you do, don't put Dexcool in it. When it mixes with air it turns to mud. Personally I never use it though, its crap in my book.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
meowMEOWmeowMEOW
^this. Dexcool was a bad try at an environmentally friendly coolant....great until it turns to algea in your tank.
Get the green regular, or the Pink Universal....or you can be gangster like me and just run water and water wetter.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I have my overflow into a old brake fluid bottle...stays empty!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
Always a work in progress
I used to use and old crown royal bottle with a hole in the lid!!
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
My beater truck has the same overflow bottle...... if mine has it and yours has it, maybe it's factory?
![]() Posted via Mobile Device
I've always just ran my overflow through the inner fender. When I teched in for the GG autocross, they told me I had to have a catch can, so I sucked down a Mtn Dew as fast as I could, then used a mini-bungee cord to tie the can to the bumber bracket under the fender.
![]() ![]() I'm thinking of having a custom one made to fit under the inner fender, so it's out of the way, but more than likely mount one under the battery tray.
If you are ever going to take it to a race track they will insist you have an overflow tank.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
no track duty here. thanks for the replies guys
always learning something new Posted via Mobile Device |
