4" lift 1/2 Ton
Have a 4" lift kit for 1/2 tons. Front springs rear shackle reversal. no U-bolts or shocks. Springs have shims. Drop steering arm.
$225.00 plus shipping OR 4" front springs rear blocks and drop steering arm $100.00 plus shipping. Rear shackle reversal kit $135.00 plus shipping. The shackle reversal was installed for a short time then removed. The springs I got used but are in great shape and are missing the bshings on one end of both springs. The sbackle reversal is an Offroad Desighn kit. Thanks Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson Last edited by Husker; 04-26-2012 at 08:06 PM. Reason: left some text out |
Re: 4" lift 1/2 Ton
PM Sent.
Just a Member
Re: 4" lift 1/2 Ton
Put me in line. Just need more info. Not well versed on lifts
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
Re: 4" lift 1/2 Ton
Heavy what do need to know? The rear shckle kit replaces the stock shackles. The springs I got in a trade not sure of manufacturer. All hardware there for the shackle kit but will need u-bolts for front springs. I had it on my truck but did not that much lift. I ended up putting add a leafs all around.
Ron Posted via Mobile Device
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Re: 4" lift 1/2 Ton
Ttt
MEMBER OF THE JUNK MAN CLUB
is any of the lift parts still for sale??
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS.. ![]() |
Re: 4" lift 1/2 Ton
Just the add a leafs.
