rear disc conversion
i read some search results.but,wasn't feeling informed.anybody done it lately with pics?
" Never look up a dead dogs butt." ![]() |
6.0 powered square
Re: rear disc conversion
I have, I'm using captain fab brackets, astro van AWD front rotors, wilwood d-52 calipers, disc disc prop valve, I'm also using front d-52s, stainless braided brake hose all the way around, and wilwood master cylinder
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 02-26-2012 at 02:14 PM. |
Is that setup a lot stronger than the stocks set up. do you stop faster with less brake fade and better proportioning?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
In the Forgotten far North.
![]() Join Date: Jul 2007
Yeah good luck with you wilwood brakes. They don't back up their warranty on anything. Once they've got your money they're done with you.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
[QUOTE=flamingbig10;5213786]I have, I'm using captain fab brackets, astro van AWD front rotors, wilwood d-52 calipers, disc disc prop valve, I'm also using front d-52s, stainless braided brake hose all the way around, and wilwood master cylinder.
thanks aaron...do you think you saved a few bucks going that route as opposed to buying a full kit?
#6 | |
sorry for the double.hopefully someone will delete the first for me.
Is there a provision for an emergency/parking brake on any of these rear disc brake set ups?
John 82 Chevy Silverado 350ci/TH350 ![]() |
that looks like a clean setup, what prop valve did you run? a wilwood, I see they have an sdjustable disc/disc. or did you just run a pre set?
thanks... |
I used the Right Stuff PV72 prop valve, DIY4x brackets, front calipers from an 85 C-10, rubber lines for an 85 C-10 for now, and the stock hydroboost master cylinder on my dually. All total I had around $350 in parts. I have pics on my 89 crew cab resurrection thread on this site.
