Old 07-29-2012, 12:23 PM   #1
steve'62
steve'62's Avatar
3/5 drop issues
installed the 3/5 drop from cpp, with new drop shocks and panard bar. Problem is it sits uneven now. It all sat even before I dropped it. 1 inch high on the passenger front and an 1 1/2 inches low on driver rear. Anyone else have this problem??
Before and after pic:
steve'62 is offline   Reply With Quote
Old 07-29-2012, 12:46 PM   #2
Pops05
Pops05's Avatar
Re: 3/5 drop issues
I had that happen to me it was the spring was not in at the top you might check it..
Pops05 is offline   Reply With Quote
Old 07-29-2012, 04:25 PM   #3
steve'62
steve'62's Avatar
Re: 3/5 drop issues
I checked it and they seem to be seated right. Do you think if I mixed up the drop shocks it could do that. The only other thing I could think of is pulling the springs out and making sure they were the same. I really don't want to have to do that though!
Old 07-29-2012, 04:35 PM   #4
Cody63
Re: 3/5 drop issues
Try swapping the springs from side to side and see if that helps.
Good looking truck BTW
Cody63 is offline   Reply With Quote
Old 07-29-2012, 04:53 PM   #5
lucifer
lucifer's Avatar
Re: 3/5 drop issues
I had a similar problem with my CPP front springs. I switched them side to side and the problem switched with the springs. After several attempts to find a problem with my installation or my truck I ended up putting a 1 inch rubber spacer under the spring on the low side.
regards
BTW nice ride!
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 07-29-2012, 05:30 PM   #6
C/10 King
C/10 King's Avatar
Re: 3/5 drop issues
Bought and had installed the same 3/5 drop coils from CPP on my 66', no leaning issues here.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 07-29-2012, 05:32 PM   #7
tazattitude
tazattitude's Avatar
Re: 3/5 drop issues
I agree with Pops. One of the springs is not seated properly.
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 07-29-2012, 07:35 PM   #8
rbar
rbar's Avatar
Re: 3/5 drop issues
Had a truck with cut coils once. Ride height changed periodically depending on how I went over the curb into the driveway. It could sit up in the bottom instead of in the correct spot.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 07-29-2012, 07:45 PM   #9
Cody63
Re: 3/5 drop issues
Yeah, I have the same springs from CPP. No issues here except the front sat to high and I had to cut a coil off the front springs.
Old 07-29-2012, 09:04 PM   #10
C/10 King
C/10 King's Avatar
Re: 3/5 drop issues
Not to hijack, but Cody how was your ride after you did this, I also wanted a rake but I didn't want to sacrifice my ride so I raised up the rear.
C/10 Rene
1971 Short Fleet
Old 07-29-2012, 10:33 PM   #11
steve'62
steve'62's Avatar
Re: 3/5 drop issues
Well I figured it out but it's still uneven. I put the 2 old rear coils next to each other and one is bent down an inch or inch and a half. So I don't know if my trailing arm is tweaked or the frame or what. I think I'm gonna throw a spacer in to even it out. I would like a little rake but am a little scared to cut the brand new springs!
Old 07-29-2012, 10:51 PM   #12
steve'62
steve'62's Avatar
Re: 3/5 drop issues
here's a couple other pics
Old 07-29-2012, 11:09 PM   #13
C/10 King
C/10 King's Avatar
Re: 3/5 drop issues
Nice!!!!
C/10 Rene
1971 Short Fleet
Old 07-29-2012, 11:15 PM   #14
Cody63
Re: 3/5 drop issues
Well, it sit pretty close to the bump stops. I only have about 10 miles on it since the lowering. The ride is not to bad. Didn't even drive it before I cut the springs so I can't comment on that.
Old 07-30-2012, 09:20 AM   #15
zeben irby
Re: 3/5 drop issues
Did you need to c notch the frame ? And it looks great. Any picks of the inside ?
zeben irby is offline   Reply With Quote
Old 07-30-2012, 09:37 AM   #16
Mack B
Mack B's Avatar
Re: 3/5 drop issues
I had the same issue, with the same kit...made a thread http://67-72chevytrucks.com/vboard/s...d.php?t=526332 haven't found a reason for it, coil is seated correctly, nothing bent or damaged ( that I can visually see)
Mack B is offline   Reply With Quote
Old 07-30-2012, 04:58 PM   #17
steve'62
steve'62's Avatar
Re: 3/5 drop issues
Mack did u do anything to try and level it out? Zebra I will try and get dome interior pics tonight.
Old 07-30-2012, 06:03 PM   #18
Mack B
Mack B's Avatar
Re: 3/5 drop issues
I haven't yet but my next project is spindles/notch. At that time imma take a good look at the springs, great lookin truck btw!
Old 07-30-2012, 07:16 PM   #19
steve'62
steve'62's Avatar
Re: 3/5 drop issues
Thanks man it's coming along. I just put a half inch spacer under the low rear spring. Now it sits almost perfect. I am planning on getting spindles too. Then a may put a 1-2 inch block in the back, along with a notch,to get the ride height I want.
