Old 08-01-2012, 03:17 AM   #1
x ReAcT x
Need your opinion. Thanks in advance
Im at the stage where I will be putting a new V8 in the truck and i have reached a dilemma. Either carb or EFI. Kidding of course im going EFI but this is the real predicament: Ls swap or splurge and go for the crate RAMJET 350. One of the main things im hoping for with this swap is Fuel Efficiency. With the LS swap im going to need a variety of things: engine, harness, fuel, motor mounts and transmission adapter. I have a 6000 budget and i really would like to stay in that range. I can get the entire RAMJET 350 with a serpentine system for 6K. Brand New, Never opened, ready to go. So heres some info about the truck. 1986 K1500 with SM465 and 3.42 gears. I would love to swap the transmission and gears but I made the decision to spend money to rebuild the SM465 and put a 600 posi-trac unit in the back. So i cant swap gears or tranny out. So this is where im at.. Which is easier? which is better? LS 6.0L or 5.7L RAMJET 350??
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 08-01-2012, 04:46 AM   #2
68Stepbed
68Stepbed's Avatar
Re: Need your opinion. Thanks in advance
I say the LS platform. Here's why. The RamJet engine is a great engine, with plenty of power/torque, but if you ever plan to upgrade anything later, well, you can't. The RamJet FI system is tuned for only that engine and cannot be reflashed, retuned, etc.
With the modern OBD II PCM system of the Gen III/IV(LSx) engines, all the technology is available for it for retunes/reflashes and upgrades.
Also, if you search around, you should be able to find a good 6.0 engine with PCM/ECM, harness, manifolds intake and pretty much everything you will need for under $2K. More than likely even get an engine/trans combo for that price.
The aftermarket is pushing towards the Gen III/IV market more and more also.
Check out LS1tech.com for lots of good info, and an enormous classifieds section.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-01-2012, 01:19 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
you posted it in the Lsx section, so subliminally you WANT an ls motor.....go get one.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-01-2012, 02:08 PM   #4
Clyde65
Clyde65's Avatar
I dont get it, you are working on a 4x4 AND you want fuel economy? JK, JK! only way for that is going with a 5.3/4l60e out of a 4x4 truck, cam, tune etc and all that. leave the 3.42's and roll that way, imo it will give you as close as you will get to economy with a 4x4 and some muscle behind it. The 6.0 wont give you economy, HP yes.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-01-2012, 02:22 PM   #5
Jonboy
Slots go on anything!
I agree. I would sell the SM465 and go 4L60E.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-01-2012, 06:01 PM   #6
mooseknuckles
mooseknuckles's Avatar
Ls..
mooseknuckles is offline   Reply With Quote
Old 08-01-2012, 06:20 PM   #7
ls1nova71
ls1nova71's Avatar
The ramjet doesn't get as good of mpg as you may think. Its fuel injected, but as was stated earlier, you can't really tune it. Not to mention its basically a TPI in disguise which is almost 30 year old technology, from back when they were just figuring out EFI. The newer Ls engines are better due to the fact great strides have been made in recent years when it comes to fuel economy. That said, if that's your goal, a 5.3 would be more suited to your needs, 6.0's are thirstier!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-01-2012, 07:27 PM   #8
Daaaanz67
Ls all the way just got done with mine and make excuses that I have to go get something just so I can drive it hard to keep my foot out of it oh so smoooooooth.
Daaaanz67 is offline   Reply With Quote
Old 08-01-2012, 09:49 PM   #9
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
LSx..... 5.3 should meet your needs, be more economical then a 6.0... and still provide roughly 350hp for fun.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-02-2012, 02:48 AM   #10
x ReAcT x
I didnt realize how cheap an LSx swap would be. Wiring harness from GMPP is $800. I can get the motor for $1000 from my friend (serpentine system included). The tanny adapter is probably $800 im assuming?? Get a holley fuel regulator and holley external fuel pump for $50 and $150 respectively. But what about the clutch and flywheel i cant find any info on them...
Old 08-02-2012, 02:50 AM   #11
x ReAcT x
Hahaha I guess i made it too obvious
Old 08-02-2012, 02:55 AM   #12
x ReAcT x
Yea fuel economy in a 4x4 is like asking for ice water in hell but i figured if im going to spend 6k for a daily driver i better make it worthwhile. The only thing is i want a manual. and since ive already spend money to rebuild the stupid sm465 im going to have to keep it. Should have just went with the NV4500....
Old 08-02-2012, 02:59 AM   #13
x ReAcT x
That definitely makes the most sense but i want a manual
Old 08-02-2012, 07:43 AM   #14
68Stepbed
68Stepbed's Avatar
Google is your friend.
http://www.google.com/#hl=en&gs_nf=1...w=1152&bih=696
Matt
Old 08-02-2012, 10:59 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
actually the prices you posted seem kinda high for that stuff....
Old 08-14-2012, 11:55 PM   #16
x ReAcT x
Haha I have been looking for that advcanced adapters piece forever through google guess i just didnt work it right. thanks for the link
Old 08-15-2012, 12:00 AM   #17
x ReAcT x
I was thinkin of just buying the 5.3 engine from turnkeyenginesupply.com
They have raving reviews from respected sources. These are the only ones that arent blocked through my proxy at work but:
http://www.truckinweb.com/tech/1204t...s/viewall.html
http://www.knfilters.com/news/news.aspx?ID=1170
and now for the downside 7000.00 excluding shipping....
Old 08-15-2012, 12:03 AM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
didn't anyone say
car-part.com yet?
i swear 80% of people (aka everyone who didn't already have a full donor, or buy a "Ready to run" engine) get swap stuff this way.
15min on car-part, a few phone calls and a trip to a salvage yard goes pretty far in getting what you need.
Old 08-15-2012, 08:29 AM   #19
whitels1
whitels1's Avatar
LS all the way, I just did this swap into my 81 K5 / SM465, I spent less than 6k, and I had to completely rebuild my engine. http://67-72chevytrucks.com/vboard/s...d.php?t=532351. Drives like a dream!
whitels1 is offline   Reply With Quote
Old 08-16-2012, 09:09 PM   #20
x ReAcT x
You did a great write up for that thread, very detailed. Ill be refering to that every now and then to point me in the right direction. How did you get the sm465 to mount to the 5.3L? did you use AA?
Old 08-16-2012, 09:20 PM   #21
x ReAcT x
I appreciate everyones input and im going with the 5.3L/SM465. Your right it just makes sense to upgrade to LS. So this is what im buying will be putting it in when i get it in the mail.
5.3L E-ROD CRATE ENGINE 6189.95
http://paceperformance.com/i-7542625...nsmission.html
ADVANCE ADAPTER LS TO SM465 627.21
http://www.advanceadapters.com/products/pn-712500m/
DIRTY DINGO ENGINE ADAPTER MOUNTS POWDERCOATED
http://dirtydingo.com/store/product_...oducts_id=1308
Well ended up going about 1000.00 over my budget but with a few more parts this should be a relatively easy swap. Nearly turn key
Old 08-17-2012, 08:30 AM   #22
whitels1
whitels1's Avatar
That's a lot of money on the clutch set up, you could use your old clutch and an NFW1050 flywheel/LS7 pilot bearing with no problems and it would save you big time. The Engine should be a sweet running machine!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
