Old 09-11-2012, 08:50 PM   #1
luifer76
luifer76's Avatar
73-87 Xmember
hey guys need a little help here i was wondering if anybody here knows if a 73-87 C30 front stock Xmember is the same or made of the same thickness metal as of a 73-87 c10 i hear some people before said that the lower control arms are different but im not sure on the Xmember any info will be greatly apreciated thanks
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 09-12-2012, 11:53 AM   #2
luifer76
luifer76's Avatar
Re: 73-87 Xmember
Bump.... so nobody knows? i thought i would get more responses here than any other forum since it has more members but i guess i was wrong...
Old 09-12-2012, 12:02 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 73-87 Xmember
I believe the crossmember is the same.
The C20/C30 lower a-arm has a larger ball joint hole compared to the C10 lower a-arm.
Keith
Convert to disc brakes.
Old 09-12-2012, 12:22 PM   #4
luifer76
luifer76's Avatar
Re: 73-87 Xmember
ok cool thanks for the response bro..... so the mounting bolts on xmember is all the same on c10 and c30?
Old 09-12-2012, 12:29 PM   #5
lolife99
lolife99's Avatar
Re: 73-87 Xmember
Should be.
I have never done this myself.
But alot of the 1/2-ton crew cab guys have.
Any reason you want to remove the crossmember?
I would just swap everything from the a-arms out.
(and the steering)
What is your plan here?
What are you trying to accomplish?
Keith
Old 09-12-2012, 02:51 PM   #6
luifer76
luifer76's Avatar
Re: 73-87 Xmember
Should be.
(and the steering)
i currently have a sectioned c10 Xmember and i want to put it on my C30 dually all im gonna swap is the xmember im gonna use the same lower and upper arms but i hate to take it all apart and find out is different and it wont fit so i thought i ask some of you guys and see if get some info i appreciate your input bro.
Old 09-12-2012, 03:10 PM   #7
Jonboy
Slots go on anything!
Re: 73-87 Xmember
I am pretty sure the crossmember Scoti put in his dually was a C10 crossmember. It bolted right in for the most part. There are a few holes you will have to drill from the sectioning process.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 09-12-2012, 03:19 PM   #8
lolife99
lolife99's Avatar
Re: 73-87 Xmember
Yep.
Member SCOTI is doing that exact swap now.
(I believe his is already installed)
Keith
Old 09-12-2012, 03:29 PM   #9
luifer76
luifer76's Avatar
Re: 73-87 Xmember
Sweet! thank you guys..
