Old 09-03-2012, 01:45 PM   #1
jwodahl
parts cab
i picked up a 67 cab that i thought was good.. turns out it was trashed in some hidden areas.. so i am trying to pull off all the parts before i scrap it.. need suggestions on little parts that would be worth my time to pull.. (i.e. hard to find) i've already pulled the cluster, fuse block and harness, wiper motor, ashtray, column, ingition and bezel, and glove box door.. any suggestions would be helpful.. thanks
jwodahl is offline   Reply With Quote
Old 09-03-2012, 01:49 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: parts cab
I'm sitting here with a '68 cab that needs rockers and corners but is in otherwise good shape. I had a '69 cab that I gutted of everything but the air dash, which means every thing that could be removed without using a chisel or a plasma cutter.
So, maybe that should be your guide....no chisel/no plasma cutter. But, there are people who have rust issues with the tops, so you might want to get a plasma cutter and remove the lid if there's no rust in it. Those people up nawth have problems with rust, I hear.
Member Nr. 2770
