Old 09-02-2012, 12:23 PM   #1
WB72
Before and After
WB72's Avatar
Electrical problem? Soilid engine start to run bad then not start.
I am a bit baffled.
I have a strong 383 built up and a few weeks ago it started to intermittently run bad, almost like a miss. As i was trying to diagnose the problem, the truck no longer starts. When it was running (badly) I checked the headers with a temp gun and were all similar in temperature, so it wasn't a bad plug.
I have HEI ignition i am thinking it is in good condition, is there someway to check the components?
I have heard it might be my ignition switch, what should I check to verify that?
There is fuel going to the engine, because it doesn't take long to smell the fuel when it is trying to start.
Any help will be very much appreciated.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 09-02-2012, 12:55 PM   #2
geezer#99
geezer#99's Avatar
Re: Electrical problem? Soilid engine start to run bad then not start.
HEI module!
Common problem.
geezer#99 is online now   Reply With Quote
Old 09-02-2012, 12:57 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
In the service manual there are steps to check the module, coil and pick up coil. All you need is a multimeter.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-02-2012, 12:59 PM   #4
Xeen
Xeen's Avatar
I am sorry to hear you are having engine trouble.
This thread would be better suited over in the "General Truck Forums - Engine and Drivetrain" section of the board because you will get more dedicated help over there.
Good Luck.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-06-2012, 12:02 AM   #5
WB72
Before and After
WB72's Avatar
New module, cap, coil, and rotor, still not running. It is running very rough and won't stay running for more than 45seconds. I dont know what to check next...
66,000 miles.
Alberta, CANADA
Old 09-06-2012, 07:47 AM   #6
Zeke's Garage
Zeke's Garage's Avatar
Have you verified that the power wire feeding your HEI, is good? Did you re-use the old resistor wire that went to the points type coil?
While troubleshooting this issue (And to rule out an issue with the ignition switch), run a single 18 gauge or better wire directly from the battery to the power input of the HEI, just to make sure the issue isn't electrical.
If it still runs poorly or not at all with the direct wire, you might want to pull the HEI and check that the shaft and gear are in good shape.
While the engine is running, does it backfire or pop through the carb?
Have you checked the initial timing of the engine again? Maybe something went wonkey with the timing chain?
Depending on who put them together, new engines can develop all kinds of crazy issues.
Good luck
Shawn
Zeke's Garage is offline   Reply With Quote
Old 09-06-2012, 08:33 AM   #7
CC69Rat
CC69Rat's Avatar
I'm thinking the resistor wire too. you may not be getting a full 12v to the HEI. ^^ In agreement with Zeke.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 09-06-2012, 09:22 AM   #8
low&slow
I had the same problem with my truck. Couldn't figure it out if my life depended on it. Just an idea, but you could just put a push button start in like I did lol. Other than that as for not running very long, You probably have a slight short somewhere lol.
Sorry not very much help
low&slow is offline   Reply With Quote
