Sleep-Deprived
Rear Coil Suspension Rebuild
I'm getting ready to redo the rear suspension on my '69 short step. Will be replacing trailing arm bushings, tracking arm & bushings, and coil springs. (probably u-bolts also)
Plan on looking at the driveshaft at the same time for possible rebuild. Before I'm this deep into it, are there anything else I should plan on replacing? The items I mentioned are obviously in need of renewal, but from experience, are there things that are not as obvious that I should automatically replace or test while I'm under there? ![]() |
