lowering the front
hi guys i have a 1968 chev truck and it has 2.5 drop spindles bell tech and drop springs but the lower control arm is making contact with the rim when turning corners wondering what can i do to make this not happen change to different control arms and can i cut one coil of the spring to lower the front a little more
Moderator
![]() Join Date: May 2007
Re: lowering the front
what is the drop on the springs? i would say no since you already have dropped spindles (i also believe belltech are 3" drop as opposed to 2.5" drop...an expert will chime in on this one). you can also trim (grind) your lower control arm contact points to correct your rubbing issues
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Nice trucks guys, please post more pics of your trucks.
#4 | |
275/60/r15 im guessing an 8 inch rim what do you have for drop spindles and drop springs on your truck leddzepp
Frequent Flyer
Bingo.... This will take care of your issue.
Check out post #6, Keith (Lolife99) has a nice pic there.
http://www.67-72chevytrucks.com/vboa...ming+lower+arm
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
#9 | |
